Vehicle: 1997 Sidekick Sport SV418
Posted: Mon Aug 13, 2018 4:30 am
It's unlikely that the pulley is the issue. It will be the belt, pump bearing, or the pump assembly. The bearing is available and so are rebuild kits with all new seals. The hardest part is pulling and replacing the bearing. You can complete a rebuild for much less than buying a reman pump. The rebuild will only add an hour to what it would take to install a reman unit.
Users browsing this forum: Google [Bot] and 42 guests
