It is currently Mon Sep 21, 2026 1:03 pm
Vehicle: grand vitara 03
Post Posted: Fri Aug 10, 2018 7:27 am
noisy power steering pulley
can I replace just the pulley or whole pump must be replaced?
any advice / costs
GV J20a SQ420
part numbers?
Post Posted: Mon Aug 13, 2018 2:58 am
Pulley?
Tried changing the belt? Pulley will probably be fine. If the pump is whining, Most likely need a new one/rebuilt if you can
Vehicle: 1997 Sidekick Sport SV418
Post Posted: Mon Aug 13, 2018 4:30 am
It's unlikely that the pulley is the issue. It will be the belt, pump bearing, or the pump assembly. The bearing is available and so are rebuild kits with all new seals. The hardest part is pulling and replacing the bearing. You can complete a rebuild for much less than buying a reman pump. The rebuild will only add an hour to what it would take to install a reman unit.
Users browsing this forum: No registered users and 58 guests
