It is currently Mon Sep 21, 2026 3:22 am
Vehicle: Suzuki Sierra
Post Posted: Fri Aug 31, 2018 12:29 pm
Big time noob question.
Recently purchased a 95 SJ soft top and went to do the gearbox oil last weekend but the entry plug has been heavily burred and I can't get her off.
My question is, is there a method to getting these plugs out in this condition.
Maybe a way to come in through the top as an alternative?
Thanks for checking this.
Cheers, S
Vehicle: sj40 s/t locked + lifted
Post Posted: Fri Aug 31, 2018 6:58 pm
you can remove the gearstick and pour it in the top, but the shifter bush may disintegrate which is always a bummer
Vehicle: 91 Tin Top
Post Posted: Fri Aug 31, 2018 7:32 pm
Cold chisel to make a groove and big pin punch in the groove to make it turn.
The gearbox is the worst one to get to and mine took serious flogging to make it move. Luckily I had a spare transfer case to steal a plug off, because the gearbox one was destroyed in the process.
Post Posted: Sat Sep 01, 2018 7:29 am
Thanks for the info. This seems like the only way to go if I can’t get purchase with a chisel.
Will post result soon.
Post Posted: Sat Sep 01, 2018 7:34 am
Thanks pete_79! Will give this a red hot go.
Cheers, S
Vehicle: 91 Tin Top
Post Posted: Mon Sep 03, 2018 5:19 pm
Good luck..
I dunno what the guy that owned my Sierra before me had done, but the filler on the rear diff needed a big breaker bar to crack it, while the drain plug on the same diff was just over finger tight.
Same with the gearbox, filler plug was mega tight and the fitting all burred over, but drain plug was hardly even done up... :?
Post Posted: Fri Sep 14, 2018 11:30 am
Thanks mate.
On hold at the mo. Replacing Transfer case first. Hopefully give the GB another go next week.
Users browsing this forum: No registered users and 67 guests
