It is currently Mon Sep 21, 2026 1:48 pm
Vehicle: 1985 Suzuki Sierra Utility
Post Posted: Sun Dec 30, 2018 2:21 pm
Good Afternoon All,
I am currently helping my dad with a farm truck (1985 Suzuki Sierra Ute which my daughters call the Yellow Truck) and am after some advice.
I am having fuel issues where I lose power under load, engine doesn’t want to idle without a high RPM. It is running very lean, requiring the choke manually closed to start and on a downshift, it can lose power all together and stall. At higher RPM, it revs freely and seems to getting enough fuel. The ute was sitting for a number of years (deceased estate).
Things done so far
Fuel tank cleaned out
New in line fuel filter
Cleaned carby with spray cleaner.
The fuel pump/carburettor are next hit list. The fuel pump looks newish (not that that really means anything) but the carb looks terrible, with dodgy zip tied closed vacuum lines, springs which don't look like they are attached to the right thing and what looks like bits missing etc. Going through the workshop manual, there seems to be a lot of electrical dodads attached which may or may not be working. Am I supposed to have a O2 Sensor for example to talk through the ECM to the carb?
I have pulled down and rebuilt a number of carbs over the years however noting that I am sure some bit and pieces are missing through farm hackery, am I better off to get an aftermarket one from ebay? I have seen that some for around $200 delivered have a manual choke (is this a simplified version without the electrical magic – which I can setup like an old fashioned carb?) or do I need a proper G13A version with the magic.
Is quality control an issue with suzuki after-market parts? I am used to after-market Indian made Land Rover Carbs were the castings are of poor quality and they need rebuilding after buying.
Any help would be great.
Ben
Vehicle: LJ50V 2 stroke
Post Posted: Sun Dec 30, 2018 4:57 pm
try the fuel pump, sounds similar to an issue I had. turned out to be the pump count supply enough fuel under load.
Post Posted: Sun Dec 30, 2018 9:17 pm
Righto.. this could be any number of things but let’s work through a few things.
An 85 that’s been sitting for a while and probably has some bush happy repairs. I’d suggest that a single drop of fuel from the tank and a new fuel filter will not be enough to rid the system of crap.
Make sure you start with fresh fuel, dump the tank and put new fuel in. You’ve got a new fuel filter but keep an eye on it, recheck it for crud getting dragged in there are replace it again as necessary.
You may also want to blow out the fuel lines. Section at a time, for example disconnect the lines past the fuel filter and before the fuel pump. Run some compressed air through the lines to blow out anything that’s in them. ***** big caution note here!!! You’ll be vaporizing fuel!!!! Ignition sources nearby are a bad idea and a fire extinguisher handy is a good idea!! I’ll leave this to your discretion but be bloody careful.
Carby jets are next on my list. With the symptoms you’ve described I’d be suspicious of the jets being blocked. There’s two brass plugs on the float chamber of the carby, once they’re out the jets can be removed with a flat head screwdriver.
My dinners ready so I’ll extend my reply soon
Post Posted: Sun Dec 30, 2018 10:13 pm
Right I’m back!!!
Time and pork chops wait for no man..
Ok so back to fuel jets. You might be able to remove them for cleaning without taking the carby off, but I reckon it’s easier to unbolt the carby and it gives you a good view to check other things.
This is where the jets are located.
And this is what a blocked one looks like, there should be a hole in the middle. Make sure they both go back into their respective place.
Ok, ^ this is what leads me to think there’s is crud in the jets. I’m going to assume that there’s no electrical problems and I’ll continue down the fuel process.
The fuel pump. You’ll notice a wee line running off the pump that isn’t attached to anything. If there’s any oil or fuel dripping out of this then your fuel pump is cactus.
If there’s not then you can either A) replace it and see if that fixes the problem, or B) make sure the pump is pumping.
IF you choose to see what the pump is pumping then I tend to do this, but again this comes with a big disclaimer!!! Even though I detail my process here I do not recommend it and if you choose to try it then it’s up to you. It’s a fire risk!!
Ok, so that disclosed and your discretion employed, I remove the fuel line at the carby so we’re downstream of the pump. I poke the end of the fuel line into a jar. Remove the HT lead from the coil so the car can’t start then turn the motor over. If it spits fuel into the jar then the pump is pumping. The flow should seem very ample! If it’s marginal then replace the pump for sure.
If you spill any fuel it’s a fire risk, the alternator that sits below is a fantastic ignition source!! Be careful.
YellowTruck wrote:
the carb looks terrible , with dodgy zip tied closed vacuum lines
They all look terrible. They’re old and in my opinion they don’t work very well anymore. I’ve had them professionally rebuilt and it worked well for a while but still wasn’t great and has gradually got worse again.
Vacuum lines are a problem. Doesn’t matter if most of them are cable tied shut as long as there is NO air being sucked in. The only vac line that should be functional is the vacuum advance that advances the timing under throttle. All the rest are emission control that can either be there or not, providing there are no leaks or open ports.
Can’t comment on this without pics to go by. As far as electrical dodads, One is idle up for when there is electrical load, if you’re running the car at idle and turn on your high beams, the radio, the fridge and whatever else and your idle increases a little then that bits working. The other is ?idle solenoid?. Not sure how it works so won’t comment on this.
There is no ECU, it’s all good old fashioned simple mechanics.
I advise against this unless you want to try it for academic purposes. They are complicated and do not usually respond to a simple overhaul kit being run through them.
Yes. The usual trick here is to find a 4K corolla carby and put that in instead. They’re a simpler carby and although they are very similar to the stock carby you can buy them new for a couple hunj and they work well. They’re a manual choke and might require re-jetting to suit the Suzuki motor. There’s a thread in the ‘good tech’ section that gives you details on how to do it etc
Depends on who you’re buying from and what it is. But generally speaking no, most stuff is fine.
See how you go with this lot and report back
Good
Luck!!
Vehicle: Suzuki sierra
Post Posted: Mon Dec 31, 2018 12:02 am
Hi
I had a similar problem. Cleaned and gapped the plugs i went 40 thou plug gap and set ignition Timing 10 deg btdc and idle needle 2 1/2 turns out to get close. Set revs at 800 rpm - 900 rpm. Now it starts first pop and revs cleanly.
It could also be spark plug leads for it to struggle under load.
Post Posted: Mon Dec 31, 2018 2:22 pm
Thanks everyone, I really appreciate the support. Will get stuck in tomorrow when I get back to the farm and will let you know how I go.
Ben
Users browsing this forum: No registered users and 52 guests
