| Anything that reduces highway sway/ drift on Sierra coily? http://auszookers.com/forum/viewtopic.php?f=37&t=56068 |
| Author: | Donkey [ Sun Oct 06, 2019 10:45 am ] |
| Post subject: | Anything that reduces highway sway/ drift on Sierra coily? |
Being new to driving these car I was shitting bricks the first time I drove through stormy weather, the crosswinds felt like it was picking up the car and shifting it half a meter horizontally while driving. Is there anything that can reduce this? Is it dangerous? I thought wider tyres might help but admittedly I know very little about cars. |
| Author: | vet 180 [ Mon Oct 07, 2019 4:25 pm ] |
| Post subject: | Re: Anything that reduces highway sway/ drift on Sierra coil |
It’s half the fun! Sent from my iPhone using Tapatalk |
| Author: | Gwagensteve [ Mon Oct 07, 2019 4:34 pm ] |
You need to determine that there isn't an actual problem. Sierras aren't great in crosswinds but they're not "frightening" Confirm caster Tyre pressure Condition of suspension bushes Condition of all suspension link brackets for bolt tightness, wear or cracks Condition of shock absorbers Toe (the only alignment adjustment on a Sierra) Adjustment of steering box Tie rod end condition Kingpin condition Wheel bearing condition. At 216k it's likely there's significant wear on many of the moving parts. This will all add up to make the car track poorly. |
| Author: | bumstein [ Thu Oct 10, 2019 10:28 am ] |
All good things that Gwagen points out, but Donkey wrote: Being new to driving these car I was shitting bricks the first time I drove through stormy weather Don’t underestimate this as a partial cause of the problem. I’ve found with many Sierra (different car I know) that it takes a while driving the car to become comfortable driving it. While I wasn’t relaxed and familiar with the car it was not behaving well on the highway. Once I was more familiar and used to the car it worked perfectly well (sort of). Especially if you’ve been driving a newer car which are more refined and have less wear and tear, tighter tolerances and a different feel. Please know that I do NOT advocate that you don’t check all the things Gwagen listed, I highly suggest you do. |
