It is currently Sun Sep 20, 2026 7:06 pm
Vehicle: JT SWB Grand Vitara
Post Posted: Mon Oct 28, 2019 5:37 am
Hi all, I'm Ken and my first foray into the forums. Daughter has just bought a 2015 SWB GV auto and we are looking at making it a little more capable off road. We pinched my wife's 4 door GV for a camping trip in Sundown National Park and found it needs some under body protection. Next some tyres, then a mild lift kit!
I don't have the facilities to make a bash plate, so do you know if the Ironman 2005 plate would fit or me modifiable (within reason) to fit the 2015 SWB?
Vehicle: 2016 Grand Vitara 3 door
Post Posted: Tue Oct 29, 2019 5:53 pm
IRONMAN have the plates for the GV3
I’ve moved the exhaust to over the diff, deleted the rear muffler and placed another next to the transmission
Post Posted: Tue Oct 29, 2019 7:15 pm
Thanks Slug. I've found and ordered the Ironman 2005 to 2015 bash plate. It doesn't go back as far as the diff so a bit of custom work to do. I'll sure check out your suggestions re exhaust and muffler.
Any chance you could post or send me a couple of pics of your setup and the details of the muffler you used? I expect you had to be careful of heat shielding too.
Post Posted: Tue Oct 29, 2019 8:01 pm
Well done Slug, on relocating the exhaust to run over the diff!.
It is very vulnerable & on the 3.2litre V6 we worked on the most, I just didn't think there was room to split it into 2 or 3 smaller pipes to get it up & over without more restriction.
Rgs, Michael
Vehicle: MY13 2.4 SWB GV (02 Paj Io)
Post Posted: Fri Nov 01, 2019 12:33 pm
I looked at the ironman ones but jeez they are heavy and overkill for my 2013 SWB
I did this instead and took the plate from further forwards to the very back of the subframe to shield radiator and entire front diff
viewtopic.php?f=14&t=55797
so far i've smashed it very very hard on rocks including getting the front wheels off the ground on a boulder that shifted, no bending but some scratching :D
Post Posted: Fri Nov 01, 2019 2:40 pm
Excellent work Bob. Did you do anything with the muffler? I’ve been thinking of finding a round one that doesn't hang down as far as the oval standard one.
Vehicle: 2010 3.2L V6 Grand Vitara
Post Posted: Sun Nov 17, 2019 4:21 pm
Not sure if Ironman fits the SWB as I have a LWB, but I've currently taken my plates off until I can straighten them again. The transfer case plates bends too easily.
Post Posted: Sun Nov 17, 2019 6:18 pm
Ironman deffinately fits the SWB, we just installed it. Unfortunately the radiator plate seems to be no longer available.
We’ll be taking it easy so it should be adequate.
Haven’t raised the car yet.
Exhaust man couldn’t do anything with the rear muffler without “making it significantly louder” ☹️
Post Posted: Sun Nov 24, 2019 5:31 am
Hi bob_oz, what fuel economy do you get out of your car? We haven't changed the tyres from stock, but the SWB seems to be quite a bit more thirsty than my wife's LWB?
Post Posted: Mon Dec 02, 2019 4:47 pm
10's with the 245/75-16 rubber.
mine's a 2.4 - definitely drinks the juice if you use the go pedal, uses minimal on cruise control though so my fuel consumption was clearly a driver issue
Post Posted: Mon Dec 02, 2019 4:48 pm
that would be easy - i'm actually looking to mount a tri-flow under the floor and remove the rear muffler completely for a sub-tank.
Users browsing this forum: No registered users and 47 guests
