It is currently Sun Sep 20, 2026 11:08 pm
Post Posted: Thu Jan 02, 2020 1:15 pm
I'm sure it's been asked but I can't find it.
My front diff seal is leaking. Before I go to the effort to remove and reseal it, I thought it made good sense to fit a steel diff and save me another job later. Its only an open diff and is going on at the moment having seen sand and a few 4wd parks. Should I just keep the alloy one?
What are the front diff ratios in a 2004 manual 2.0L grand Vitara with alloy housing?
Which model can I direct swap a steel diff from our do I need to put my centre in a new housing?
Post Posted: Thu Jan 02, 2020 4:32 pm
Yours will be a 4.8, front diff from a 03 04 05 V6 auto will have the same ratios but has a different pinion mount so get the mount with the diff
Post Posted: Thu Jan 02, 2020 4:54 pm
If you want to check your ratio first, chock front wheels jack up rear axle with the car in neutral turn a wheel 1 rotation the tailshaft should rotate 4.8 times
Post Posted: Thu Jan 02, 2020 11:19 pm
First - I'd suggest you jack one rear wheel off the ground and rotate that wheel two full turns whilst counting the tailshaft turns - if you jack the entire axle you'll need to rotate both wheels at the same speed.
Second - which seal is leaking - if it's the right CV axle, you can probably repair it for a lot less than it'll cost to replace - yank the CV axle and fit a new seal along with the nylon support bush.
Post Posted: Fri Jan 03, 2020 1:43 am
Has been a while since i did this and couldn't remember if it works just jacking up one wheel :)
You say turn the wheel two full turns? Why two? One full turn of the wheel should turn the tailshaft 4.8 times yeah?
Post Posted: Fri Jan 03, 2020 4:08 am
Differential action is the reason you need to turn the wheel two full turns.
Post Posted: Sun Jan 05, 2020 7:29 pm
So two turns of the wheel 4.8 of the shaft? And the front diff has to be the same ratio but without the diff locked you can't check the front?
It's leaking from the housing not the cv. I already have the nylon bush.
Post Posted: Sun Jan 05, 2020 8:48 pm
Im pretty sure when i did it i turned the wheel one rotation and the tailshaft did 4.8 turns, same thing i checked a front diff i bought recently i turned the flange just over 5 turns (5.12 gears) and the crown wheel did one full rotation
I might be missing something but that's how i see it.
Post Posted: Sun Jan 05, 2020 9:17 pm
Fordem is correct Joe.
Post Posted: Sun Jan 05, 2020 10:16 pm
Not the first time i been wrong :oops:
Is the way i checked that ^^^ front diff correct?
Post Posted: Mon Jan 06, 2020 4:12 am
If you have CVs pop a couple in and try it - hold one steady so it can't turn and then rotate the flange, the other CV will rotate twice as fast as the crown wheel - differential action - if it's a GV diff, you'll need to engage the freewheel clutch.
If you have the diff out as you do, the easy way is to count the teeth and divide crown wheel by pinion.
Post Posted: Mon Jan 06, 2020 5:52 am
That front centre has a locker
Vehicle: LJ50V, SJ70
Post Posted: Mon Jan 06, 2020 7:54 am
That's exactly how the pinion and ring gear work, in the way you describe for the 5.12, but for a normal/open differential if one WHEEL is fixed (eg on the ground) then you need to turn the other wheel TWICE to turn the ring gear ONCE, due to the spider gears that connect the two axle shafts inside the diff. So for the 4.8 diff, you need to turn one wheel 2 turns to count the rotations of the flange.
But if you'd told us that the two front axle shafts were connected by Locker.............
Post Posted: Mon Jan 06, 2020 9:34 am
Yeah ok that make sence now.....hopefully i haven't confused the op to much :oops: :lol:
Post Posted: Mon Jan 06, 2020 5:23 pm
When you say pinion mount do you mean the mount arm from the diff to the chassis?
Post Posted: Mon Jan 06, 2020 7:25 pm
The one that mounts to the crossmember
This pic shows to two different mount types, top one is what yours should look like (apart from being broken)
Users browsing this forum: No registered users and 38 guests
