It is currently Sun Sep 20, 2026 2:32 pm
Vehicle: Suzuki Sierra 1993 SJ70
Post Posted: Fri Feb 07, 2020 11:16 am
Hi, I just ordered this tora water pump https://www.onlineautoparts.com.au/products/ZPN-09635
to change in my 1994 SJ70 just wondering what else I should be changing at the same time?
Post Posted: Fri Feb 07, 2020 11:53 am
Timing belt
Post Posted: Fri Feb 07, 2020 12:03 pm
Chuck a vitara viscous hub & fan on while you're at it.
Post Posted: Fri Feb 07, 2020 3:29 pm
Joe wrote:
Timing belt
.. and timing belt tensioner.
And buy a new fan belt. Don't bother re-using the old one (unless you've just replaced it in the last couple of months). Keep the old one as your travelling emergency spare.
Post Posted: Fri Feb 07, 2020 8:07 pm
I'd probably stick some new radiator hoses on there too. It would be worth sourcing a crank and cam seal so you can replace them if they are leaking.
Post Posted: Fri Feb 14, 2020 9:52 am
Awesome thanks guys I will get this sorted ASAP.
Users browsing this forum: No registered users and 36 guests
