It is currently Sat Sep 19, 2026 7:07 pm
Vehicle: 1995 SIERRA
Post Posted: Wed Aug 19, 2020 5:28 pm
After 2yrs in storage I finally sourced a replacement engine for my 95 sierra. I havnt done an engine swap/install before but worked small things on my various other cars ive owned eg gearbox removal/install, changed clutch on hilux, done my brakes and suspension ect.
Is there anything in particular that I need to be wary of installing a replacement engine on the sierras?
I have typed in as many phrases into the search bar as I can think of but seems to be no topics/guide on the actual install.
Is it so simple that one doent need a guide ect?
Thanks in advance cant wait to get her on the road again.....
Post Posted: Wed Aug 19, 2020 11:26 pm
Gudday Lards!!
Glad you’re getting the jalopy back on the road!!
It’s pretty straight forward, no big traps that I’m aware of. Two things that spring to mind which can be a little tricky are;
the plate that sits between the motor and bell housing can be a pain, slips off and misplaces while trying to get the motor and the bell housing together. I’ve been known to pop a couple small cable ties on to keep it in place, once the motor and bell housing are close I’ll pull the cable tues out.
The other is getting the motor and bell housing together. You’re trying to get the gearbox input shaft to match the clutch splines and the end to get into the centre of the spigot bearing. The input shaft has to line up and be level, can be a little bit of a pain. I don’t have any real tricks, except it’s not a good idea to get the threads on the bolts started and try pull the two together.
And just in case you haven’t done so already, it’s a good idea to put a new clutch and throwout bearing while you’ve got the motor and gearbox apart. Unless you know when the clutch was last replaced it’s easy and cheap enough to do it and if it shat itself shortly after you’d be up for pulling it all apart again.
Enjoy!! Post a pic when she’s all running again sweet as a nut
Post Posted: Thu Aug 20, 2020 6:23 am
Thanks for tips mate ill be sure to remember them.
Post Posted: Thu Aug 20, 2020 4:14 pm
Take the front clip off and the radiator out. Then pull the motor and gearbox out as one unit. Replace the same way.
Post Posted: Thu Aug 20, 2020 9:37 pm
Not a rubbish idea at all!! Good way to clean up the seams and seal them off to keep the rust at bay.
Post Posted: Fri Aug 21, 2020 1:35 am
Motor and box comes out pretty easily together even when front clip is left on. Only takes 5 mins to pull motor and box, cable tie the jackshaft into the back of the gearbox, this prevents oil spewing out the box when its on an angle.
Pulling front clip can be way more trouble than its worth
Post Posted: Fri Aug 21, 2020 8:26 am
I also support pulling the clip. makes the rest of the job go so much easier.
Vehicle: Rusted out much loved Sierra
Post Posted: Fri Aug 21, 2020 12:26 pm
https://auszookers.com/forum/viewtopic.php?f=17&t=36562
I used this link the other day when I removed my front clip. It was much simpler than I first thought it would be.
