It is currently Sun Sep 20, 2026 8:27 pm
Vehicle: Suzuki Grand Vitra
Post Posted: Tue Oct 06, 2020 4:09 pm
changed all the gear oil dif x2, gearbox, transcase
now i have this gear oil burning smell, though not bad but noticeable, No sign of leaks
the transfer case was low less than 500ml came out an sure i put at least a liter back in but cant see that leaking
will check to see if its still full next few days
Post Posted: Tue Oct 06, 2020 8:55 pm
Is there a question here?
I'd say the only way you can get an oil burning smell is oil on (or in) the exhaust, and after an oil change exercise I would suspect spilled oil.
Post Posted: Wed Oct 07, 2020 1:48 am
aware of that but after 1,000km still a slight smell
Post Posted: Wed Oct 07, 2020 6:43 am
Are you sure what you're smelling is gear oil?
Post Posted: Wed Oct 07, 2020 9:02 am
gear oil is distinctive
Post Posted: Wed Oct 07, 2020 9:53 am
Burning gear oil certainly does have a very distinctive smell, but you should never smell it whilst driving the vehicle, that would imply gear oil is landing on the exhaust close to the engine. A visual inspection should be adequate to determine the source- it will have made quite a mess.
Users browsing this forum: No registered users and 49 guests
