It is currently Sun Sep 20, 2026 8:27 pm
Vehicle: MG410 Gypsy
Post Posted: Wed Nov 04, 2020 12:55 pm
Hi all, my first enquiry since 2015 haha!!
Ive just bought a Sierra with 4.16 Transfer case gears.
The transfer case has standard arms and no ring..
What are your experiences?? what's the preferred method to strengthen the arms or buy the ring?
I found zukparks TCSpine.
https://www.zukparts.com/Suzuki-Samurai ... Case-Spine
Post Posted: Wed Nov 04, 2020 1:44 pm
I prefer strengthen arms to the rockring
Ive seen cases break with both configurations.
Strengthened arms with upgraded transfer mounts is my prefered. If you use the ring be sure to square it up to the holes and clearance the holes to make it fit rather than force the bolts
Post Posted: Thu Nov 05, 2020 8:48 am
Thanks Rocky, I had a calmini cradle on my last car that worked well.
As suggested, i might just strengthen the arms that are on there.
Post Posted: Thu Nov 05, 2020 5:30 pm
Also, invest in some Coliso transfercase mounts. Install them once, then walk away and never worry about them ever again :)
Post Posted: Fri Nov 06, 2020 7:06 am
Thanks Ross, They are currently sold out. I just PM'd the page on FB
Are they steel with no rubber?
Post Posted: Fri Nov 06, 2020 7:31 am
Land rover mounts are also another option with some modifications
Post Posted: Fri Nov 06, 2020 7:56 am
Coliso have just replied and have mounts in stock. I have some on the way
Thanks for the replies.
Post Posted: Fri Nov 06, 2020 8:48 am
I do not recommend “upgrading” the rubber mounts. Upgrade the arms as much as you like, that makes sense (I dislike rings, but there’s a number of ways of preventing arms bending) but the transfer needs to float to take torque spikes off the gears. Mounting the case more firmly with harder mounts or through bolted mounts transfers stress into the gears.
If you’re breaking stock rubber mounts replace them with factory genuine mounts (these have a Bridgestone logo on them) they’re flexible enough the transfer will hit the floor without the mounts breaking. These are old cars now and the rubber has typically dried out and perished. Generic aftermarket replacements are not strong enough for even a standard car and fail readily.
Whilst it’s true 1.0litre Sierras use through bolted mounts (and 4 not 3 like a 1.3) the rubber is very soft and the way the mounts work there’s lots on movement in them.
Users browsing this forum: No registered users and 48 guests
