It is currently Mon Sep 21, 2026 3:12 am
Vehicle: Holden Drover, Suzuki LJ81
Post Posted: Wed Jan 06, 2021 12:33 pm
I just got a new column switch because the headlights didn't work with the old one. everything else worked. I connected it up and the windscreen washers/wipers, horn and headlights work but now the hazard lights and indicators don't work. my car is a Holden drover and I bought a Sierra switch. I was told that it wouldn't fit my drover and it didn't. the mounting points were wrong. I drilled parts so they would fit and i'm sure that the circuit board wasn't hit.
Anyone got any idea
Thanks
Gus
Done myself a mischief.
Vehicle: MG410 Gypsy
Post Posted: Fri Feb 05, 2021 10:39 am
Check the listing you bought.
https://www.ebay.com.au/itm/COMBINATION ... SwZn1fkYgh
This says its for a holden drover, did you buy the right column switch?
Post Posted: Fri Feb 05, 2021 11:04 am
WHY are you starting a new thread on this?
https://auszookers.com/forum/viewtopic.php?f=37&t=56818
Is this the same switch or a new one? I got you the relevant diagrams, everything you needed to sort the problem out, or at the very least determine that the switch was not compatible - perhaps it's time to take the car to an auto-electrician.
Users browsing this forum: No registered users and 57 guests
