I wouldn't try it unless I already had the extractors. SJ40 chassis are wider. The stock SJ40 exhaust manifold doesn't fit an LJ80 because it fouls the chassis.
I have a set of extractors for the LJ that I am told are from an LJ. But they are a little old and Shitna needs a set as the manifold is crumbling into pieces. So I was hoping to put the old set on shitna and new set on the LJ. Not a big deal in the grand scheme of things but still.
I swapped extractors from maruti 1ltr lwb to lj80 800cc without issue. The ones i used were 4 into 1 from ebay not the more common wildcat type 4 into 2 into 1
Users browsing this forum: No registered users and 63 guests
