Vehicle: Suzuki sierra SJ413
Posted: Thu Jun 03, 2021 8:21 pm
1. what's involved with the g16b Baleno coil pack engine swap into a sierra? Will be using as daily driver still, and off-road heaps
2. Heard you will need to modify the sump to fit the crank angle sensor into the Sierra sump, and a modified oil pickup?
3. will it bolt straight in? or modify/change the engine mounts? yes buy an adapter plate to suit gearbox.
4. parts wise, better off getting a baleno car cheap from wreckers? therefore everything's there? ecu wiring? something about the dash? or speedometer needed pulling apart or swapping bits? vss? cel?
5. extractors?
6. anyone running a turbo on them? or upgraded pistons etc..
7. keep the 1.3l sierra radiator and fan? or go thermo fan? or run both perhaps? any overheating problems?
8. heard with the coil pack version there is no need to bash fire walls? or just a little anyway?
any other information or things to consider? Thanks
Users browsing this forum: No registered users and 49 guests
