It is currently Thu Nov 05, 2026 11:42 pm
Vehicle: 1991 Vitara, G16A Manual 3door
Post Posted: Fri Jul 15, 2022 3:13 pm
Hey everyone,
I’ve recently purchased a 1991 Vitara with the G16A in it and looking at what’s the recommended or upgraded parts for the list below:
- Ignition Coil
- Spark plugs and leads
- Distributor
- Carburettor upgrade or rebuild if the stock carby is the best
Basically looking to change a few things out due to a bit of a rough idle and stalling once it’s warm at a set of lights.
Drives great, sits on 100km perfectly fine, then will go to a set of stop lights and will either stall if I don’t hold up the revs a little or will bounce between 0rpm-500pm
Post Posted: Sat Jul 16, 2022 6:00 am
Plugs, leads, distributor rotor & cap - for no other reason than they are tune-up/maintenance items and most likely have been done in a while, NGK copper plugs are fine, as any any decent set of leads, nothing special needed.
For the stalling, make sure the EGR valve is clean & not sticking open or partially open.
