It is currently Sun Nov 15, 2026 6:25 am
Vehicle: buying
Post Posted: Wed May 31, 2023 5:53 am
Hi,
I got a leak at the front main seal after changingy timing belt and having to replace the timing gear on the crank. It losses a lot of oil when driving but not while idling.
I ended up getting the mechanic to replace the front main seal while getting a rwc and he said I had damaged the seal when levering the gear off. I thought I thought I was careful.
Now getting the car back the leak is still there but not as bad. I'm wondering if it may be a worn crank where the seal goes and if a speedy sleeve would be easy to install and if anyone has done that?
Regards,
Tim
Post Posted: Wed May 31, 2023 5:08 pm
What does your mechanic say when you told him it was still leaking?
Vehicle: buying
Post Posted: Wed May 31, 2023 7:25 pm
He said the crank where the seal sat felt perfectly fine and he didn't think it was a problem. I do trust the mechanic but I'm getting to take another look. Just thought I would see if there was another thing that would cause the problem
Users browsing this forum: No registered users and 47 guests
