It is currently Tue Nov 03, 2026 6:43 pm
Vehicle: sierra sj70
Post Posted: Wed Aug 23, 2023 6:35 pm
G'day guys, does anyone know to change my stud pattern to that of a 79 series 5 stud if at all possible, I don't have the brain power to figure it out.
cheers
Post Posted: Wed Aug 23, 2023 10:49 pm
The rear drums are easy- have a machine shop re drill the new pattern. I don’t think it’s easily achievable with the front hubs. It would require the existing stud holes to be welded up and new holes drilled. There isn’t much meat to work with. What rim size and offset are you chasing? Rims and tyres suitable for a 79 series will perform poorly on a sierra due to their weight and stiffness
Vehicle: Coily.
Post Posted: Thu Aug 24, 2023 8:46 am
cheers
Bad idea in every aspect.
Post Posted: Sat Aug 26, 2023 8:40 pm
17X8 not sure of the offset but i got them for cheap and was hoping it would be doable, cheers for the help
Post Posted: Mon Aug 28, 2023 8:31 am
The cost of machining, new studs, wheel nuts, etc will make the cheap wheels very expensive, even if there is sufficient material in the front hubs to space the stud out 12.7mm (I’m pretty sure there isn’t) Any tyre that requires a 17x8” wheel will be very big and heavy and require substantial work to the car to fit.
Users browsing this forum: No registered users and 23 guests
