| (early) G16b ECU pinouts http://auszookers.com/forum/viewtopic.php?f=37&t=57837 |
| Author: | shakes [ Tue Feb 11, 2025 7:59 am ] |
| Post subject: | (early) G16b ECU pinouts |
The 2nd of many rookie questions from me. Doing a G16b transplant. Can find about a dozen different wiring diagrams. NONE that exactly match mine. Reverse engineering this is what I've come up with.... The engine runs on the stand, and doesnt look like it throws faults. If anyone can comment on the below to spot issues let me know. 4 points I've messed up on. (i'll go back through the cut off bits of loom and hope I've labelled it. A9 - Yellow. Black Trace. I think this was AC? A11 - Brown, Yellow trace. Blue rings. B13. (this could of been empty and I forgot to write it down) B19. Grey, White Trace. Red rings. Did A1 get power from somewhere? |
| Author: | fordem [ Tue Feb 11, 2025 9:12 am ] |
| Post subject: | Re: (early) G16b ECU pinouts |
See if the attached file is of any help. |
| Author: | shakes [ Wed Feb 12, 2025 9:29 am ] |
Thats absolutely perfect and beyond what I need. Thank you again! Engine is apart now doing valve clearances, inspecting bearings, new timing etc etc. Will fit in the next few weeks... so expect some more rookie questions soon. |
