It is currently Sat Sep 19, 2026 10:31 am
Board index » Talking About Stuff » Street Suzukis
Post new topic Reply to topic  [ 194 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
Post Posted: Fri Jun 13, 2014 4:03 pm
Swaybars arrived, rear took longer to unpack than fit, front looks hard so it can wait
No springs or struts, Suzuki sport sold out days before my order :(
Post Posted: Fri Jun 13, 2014 5:27 pm
Looks sexy!!
Post Posted: Fri Jun 13, 2014 6:57 pm
Fronts sitting in the garage, gotta see a guy about some bushes
Post Posted: Fri Jun 27, 2014 12:24 pm
Put the front in the other day, had to drop the front subframe thing down which is interesting when your jack is too short
Works well though, will need an LSD to deal with coming out of tight corners though
Post Posted: Fri Jun 27, 2014 12:39 pm
Just sway bars for now? Or full spring/strut setup?
Post Posted: Fri Jun 27, 2014 1:52 pm
Just sway bars, I am back to the drawing board on what to do for struts, the stock springs can stay cause it doesnt need to be any stiffer or lower
ill probably put Koni yellow inserts in or something like that
Post Posted: Sun Jun 29, 2014 3:48 pm
Sydney suspension.... Great team who know their shit. I can help with shipping if you like.
They're on Facebook if you want to see what they're about.
Post Posted: Mon Jun 30, 2014 5:32 pm
Bilstein looks to be an option as well
Anyone know what the combustion chamber volume and valve size are on an M18 head?
Post Posted: Mon Jun 30, 2014 9:04 pm
Chop wrote:
Danielle's swift sport has been excellent, bought new and never had a problem with it. It just hit 80,000km and is an 09.
The paint/body is cursed i'm sure, rocks and a car park hit and run and car doors its had to have a few touch ups :roll:
They go well for what they are, handle well and love to be revved just like all suzuki's.
I drove a normal swift and it just doesn't compare to a sport, so much better with the 1600 high compression motor over the standard 1500.
On sunday we went and traded in her 09 sport and have 14 coming in silver.
Post Posted: Wed Sep 17, 2014 4:17 pm
shiny pompoms
I plastidipped the cowl as they have a habit of turning shitty grey at the base of the screen
Post Posted: Wed Sep 17, 2014 8:53 pm
You must be bored!
Post Posted: Tue Sep 23, 2014 3:48 pm
pompoms
Screw you to the suspension shops that said these aren't available, they aren't for Australian ones only Euro ones bla bla bla
might be a little stiffer just cruising around but are a massive improvement on crappy roads and uneven surfaces and bumps mid corner
Post Posted: Wed Sep 24, 2014 11:30 am
Nice, you can't go wrong with Bilsteins. I bet the cornering is a lot better. :)
I wish there was something other than KYB available for the Kizashi. :(
Post Posted: Tue Sep 30, 2014 6:03 pm
Nothing to see here move along
Post Posted: Tue Sep 30, 2014 6:24 pm
AHHHHHHHHHH tuning time heyyyyyyyyyyyyy
Post Posted: Tue Sep 30, 2014 7:49 pm
How much will you get out of it before it goes bang?
Post Posted: Wed Oct 01, 2014 6:54 am
Another 40kw apparently
Post Posted: Sat Oct 11, 2014 12:35 am
what ya dooing? 8O
Post Posted: Sat Oct 11, 2014 7:34 am
getting ready for the end of the world, Mad Max style
Post Posted: Sat Oct 11, 2014 10:27 am
Fuck yeah Armsup
Post Posted: Sat Oct 11, 2014 4:15 pm
Wooooo! Moar details!! You browsed this site yet? http://monster-sport.com/e/parts/comple ... index.html
Post Posted: Sun Oct 12, 2014 10:23 am
http://www.trust-power.com/event/swispo ... file=power
Most things for this are discontinued now cause everyone that bought them are tossers that just wanted to lower them with China coilovers and put some heavy 18's on them.
Been wiring the emanage in first to make sure its all ok, Trust password the thing so you cant see anything or do anything, whatever its doing to alter the map sensor output is annoying the stock ecu but i cant look at anything to see what its doing
Assholes wont give up the password either so going to have to reset it and have it dynoed from step one.
Post Posted: Sun Oct 12, 2014 1:38 pm
Could throw the oscilloscope on to it
Post Posted: Sun Oct 12, 2014 5:51 pm
As in you cant see what the map setting is, seeing what goes in and out is easy enough.
Anyway I fixed it, its wired to intercept the map signal (soley so the stock ecu never see's pressure) but the ecu isn't set to actually use the map so it wasn't outputting anything, I turned it on, sent it to the ecu and it all works.
A bit more digging it seems all the password does is stop you seeing the maps and altering them, you can still alter settings and send them, data logging with injector adjustment and output duty cycle works as well, so it doesn't take long to drive around and see what its doing, which is add heaps of fuel anytime you touch the throttle (perfect for an M18 Jimny!)
Post Posted: Mon Jan 19, 2015 8:12 pm
Finally got around to getting a modplate, turns out you don't need an emissions test in QLD cause there are no places that do the test so the inspection takes about 18 seconds
Post Posted: Mon Jan 19, 2015 8:14 pm
foooookingwhoooooosh Armsup
Post Posted: Mon Jan 19, 2015 8:56 pm
Nah its more of a goat inhaling a cat whine than a woosh.
Post Posted: Thu Feb 05, 2015 11:36 am
So hows it go?
Post Posted: Thu Feb 05, 2015 8:10 pm
I need a ride/drive in this!!
Post Posted: Fri Feb 06, 2015 7:41 pm
Its got heaps more torque, though it feels a bit flat over 4500 rpm which is a big change from before.
Almost finished making up water injection for it, then exhaust, pressure regulator and a smaller pulley
Users browsing this forum: No registered users and 19 guests
