It is currently Fri Sep 18, 2026 8:51 am
Board index » Talking About Stuff » Street Suzukis
Vehicle: Cobra 427
Post Posted: Sun Jun 02, 2013 9:08 pm
Post Posted: Sun Jun 02, 2013 9:16 pm
burnout pics not loading?
Post Posted: Sun Jun 02, 2013 9:33 pm
The jimny would have had a better chance of a skid than the Mazda :thefinger:
Vehicle: Cobra 427
Post Posted: Sun Jun 02, 2013 9:52 pm
does a better skid than a gay vitara
Post Posted: Sun Jun 02, 2013 10:00 pm
not sure if thats aimed at me, but i've always had a soft spot for rotors... don't mind Rusho, he sits down to pee.
i've always said if aliens were to invent a horsepower machine it would be based on a rotary. 8)
Vehicle: Cobra 427
Post Posted: Sun Jun 02, 2013 10:32 pm
small and zippy as
what you reckon would be a good upgrade?
Post Posted: Sun Jun 02, 2013 10:36 pm
seeing fast n furious is on the tele... you need NOS, 2 of the big ones & you need them by tonight. :P
Vehicle: Cobra 427
Post Posted: Sun Jun 02, 2013 10:44 pm
Post Posted: Mon Jun 03, 2013 6:58 am
I'm only taking the piss :mrgreen: Everyone has different tastes in cars. Hell, I drive a Coily pompoms pompoms
Post Posted: Mon Jun 03, 2013 11:01 am
Rusho wrote:
Hell, I own an almost drivable Coily pompoms pompoms
Lets get the facts straighter than you at least :P :mrgreen:
Post Posted: Tue Jun 04, 2013 8:47 am
Jameszook wrote:
small and zippy as
Skies the limit.
Extended port, "J" port, bridge port, peripheral port.
Exhaust and fuel it to match. Upgrade apex seals, turbo, etc
$ will eventually stop you.
I miss my rx7. :(
SS
Post Posted: Tue Jun 04, 2013 9:46 am
So on this topic, can anyone tell me what I need to modify on a 13B to get it to run vertical? I'm led to believe that one of the rotors will fill with oil if I do so :?
Post Posted: Tue Jun 04, 2013 10:17 am
Post Posted: Tue Jun 04, 2013 12:10 pm
DMAC wrote:
Jameszook wrote:
small and zippy as
Skies the limit.
I miss my rx7. :(
this might be sacrilege but probably way more reliable... LS1 8O 8)
Post Posted: Tue Jun 04, 2013 4:32 pm
oh LS1s are going into everything these days!
Post Posted: Tue Jun 04, 2013 8:15 pm
Nice looking 7 mate.
Nothing wrong with the reliability of a rotary...I've been through more toyota 4AG-E's than mazda 13B's.
Just like any engine, treat it right and it will last.
Vehicle: sierra
Post Posted: Fri Jun 07, 2013 12:19 pm
would love to see that ls-7 going. would be evil as :D
Vehicle: Cobra 427
Post Posted: Fri Jun 07, 2013 12:23 pm
thats ill as but i dont think i wold ever do it
Vehicle: 1997 Suzuki Sierra
Post Posted: Mon Jun 24, 2013 9:58 am
Money pit, but as WAS12A said if done properly there's nothing wrong with them.
My start would be compression test as a starting point and get an idea of where the seals are at. Just that can tell you whether you're gonna have a bad time or not haha.
And after market ecu.
And Bridgeport.
And gt35.
And 50psi boost.
And a helmet haha
Post Posted: Mon Jun 24, 2013 11:12 am
50psi... you watch too much F&F
Post Posted: Mon Jun 24, 2013 6:19 pm
And nos?
Post Posted: Tue Jun 25, 2013 9:52 pm
Motec system exhaust is a must. Momo suck off valve?
Vehicle: 1999 Jimny with to much!
Post Posted: Wed Oct 30, 2013 8:03 pm
Keep the motor stock. ( no port work )
Bolt on a hybrid Ser 5 rear and body with a T04 .60 front and you will be making boost very low, around the 1500 rpm mark all the way to 7500.
Leave the 550cc primary injectors and hunt down some Siemens 900cc injectors for secondary. You will have to get the plastic housing machined down a little to fit. At 37 psi of fuel pressure they will flow 1100cc.
Try getting your hands on a Ser 5 inlet manifold, they will flow over 400 rwhp easy. Remove the choke set up as you wont need it and at higher boost it will blow closed.
Save for a Haltech ecu. Or go a micro dump. ( Micro Tech ).
Watch fitting a front mount cooler with the Ser 4/5. No mater what people tell you a bar and plate core is a F*&^*ing waste of time on the street. Tube and fin core is the best way to go. Also, dont go for a 3 inch thick core, you will find your car will over heat all the time. Inter-cooler pipe work larger than 2 1/2 inch is a waste of time and will just give you pressure drop.
With the above set up my last rotor made 350 rwhp on 19 psi. But I had 3mm seals and I had the exhaust ports cleaned up to flow better.
Post Posted: Sun Nov 03, 2013 8:57 pm
That is a nice rx4 8) i always wanted one.. Might still get one yet..
Vehicle: suzuki jimny
Post Posted: Mon Dec 02, 2013 11:51 am
i must say no matter what rotors will always have a place in my heart just the look and sound and the old school make to them
Post Posted: Thu Jan 09, 2014 8:15 am
Next door neighbour has a 323 Panel with a 12A that runs High 10's. That sits next to his Rx4 that runs 11's. I cry a little bit each Saturday when he loads them up to take them out to the strip... such a beautiful sound.
Vehicle: 1988 suzuki vitara
Post Posted: Sun May 11, 2014 8:24 am
Iono was surprised that my vitara spun twins in second haha... Love rotors I have a 76 coupe but I'm throwing a 347 Windsor in it in the future once I finish my vitara build I start on the coupe.
Users browsing this forum: No registered users and 23 guests
