It is currently Thu Nov 05, 2026 7:42 am
Post new topic Reply to topic  [ 499 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17
Post Posted: Thu Jan 08, 2015 6:23 am
I took it to the high country to wash its undercarriage :)
Vehicle: Suzuki Jimny 2009
Post Posted: Thu Jan 08, 2015 6:35 pm
Where was that Chris?
Post Posted: Thu Jan 08, 2015 8:12 pm
Entering granny flats in Lake hovel area
Post Posted: Wed Jan 14, 2015 6:06 pm
Got my days mixed up.
It is entering Granny Flats, which was after Mansfield, pretty sure track started in Howqua Valley.
Post Posted: Wed Jan 14, 2015 7:00 pm
Masters Tk
Post Posted: Thu Jan 15, 2015 2:49 pm
Thought I'd do some minor leak sealing.
From the mudguard area.
But couldn't reach it without pulling out the fixed section of the bed base. :|
This proved rather difficult, and I gave up and broked it out. :twisted:
As original single bit was also the bracing for frame and mudguards,
I fitted some galv bracing first, then the more easy to access strapping.
Woods a bit lighter than the ply sheet, but adding braces and 2000 screws, probably same weight over all.
Now I can just remove whatever section I wish to access. :mrgreen:
Though hopefully will never need to.
Somehow I forgot to add flashing to the wheel guard/side area, but has only just started to leak.
So will do that, or a ton of silastic soon.
Post Posted: Thu Jan 15, 2015 2:52 pm
PS, may have only been 100 screws, but my hand feels like it did a lot more.
Post Posted: Tue Jan 20, 2015 6:04 am
Opted for a ton of silastic,( neutral cure, mould resistant ) as my back said no more work.
If it works, great, if not can do some flashings later.
Post Posted: Wed Feb 04, 2015 11:12 am
Found me camp stove next to my pillows, so decided it was time to fit load restraint points.
Don't usually carry much there, but what I do carry should stay where I put it now :)
Leaf sprung trailers are quite hard on contents when off road.
I would never carry anything fragile in there.
Hence why I stay in the car ;)
Vehicle: 96 tin top sierra 31's omes
Post Posted: Wed Feb 04, 2015 11:21 am
This may have been asked before.
What Tyre pressure do you usually run for road and off road (gravel) trailer pressure that is
Post Posted: Wed Feb 04, 2015 11:31 am
I have been experimenting with pressures.
So far I have found 10psi best, on and off road.
Could go lower off road, but drag was bad on road.
If get into soft sand probably go lower.
Long highway trips I go to 15 to save fuel and tyre wear.
10 is it for now.
Post Posted: Thu Apr 09, 2015 8:02 am
I used 8 on the Vitara and 6 on the trailer for this trip
Post Posted: Wed Jul 01, 2015 6:58 pm
Vehicle: Suzuki Vitara 1992
Post Posted: Wed Aug 05, 2015 10:14 pm
Awesome build mate, just went through the whole thread really good read.
Post Posted: Wed Aug 05, 2015 10:41 pm
Thanks, it is trip planning time again.
Vehicle: 91 Tin Top
Post Posted: Tue Jul 05, 2016 10:17 pm
Hi mate, just wondering your thoughts on the battery box up front.
Do you still have it up there?
And have you found any issues with it being exposed, like through water crossings or on muddy tracks?
Just looking at options for moving the batteries out from inside my trailer and was thinking about doing something similar to yours.
I don't really want to throw a big heavy tool box on the front if I can avoid it.
Post Posted: Wed Jul 06, 2016 8:01 am
Not had any problems with water or mud, but fine dust gets into the box.
Box has breather holes for the battery..
No problem with weight on drawbar, or tow ball, but my battery is light.
Weight could become an issue for ball weight, if battery too heavy.
If I fitted a stone guard, it would be behind that. Have not found a need for that, yet.
Post Posted: Wed Jul 06, 2016 8:33 am
Bigger battery, now, only reason was it was free.
Little battery was a 7ah, this is 24ah.
Threw a bit more paint at camper recently.
Vehicle: 91 Tin Top
Post Posted: Wed Jul 06, 2016 9:27 am
Cheers mate.
For some dumb reason I hadn't given much thought to dust. Was mostly worried about water/mud/rocks being thrown up from the car tyres.
I'm still undecided on the best solution for me at the moment, but I'm sure I'll come up with something soon. :wink:
Thanks again.
Users browsing this forum: No registered users and 3 guests
