It is currently Thu Nov 05, 2026 8:45 am
Post new topic Reply to topic  [ 108 posts ]  Go to page Previous  1, 2, 3, 4
Post Posted: Tue Oct 28, 2014 6:38 am
What did you end up doing with the wheel arch outer skin, just squared off or something more creative?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Oct 28, 2014 9:00 am
I'mm going to glue the panels on streight then cut the actual arch as small as i can to get a wheel off while the trailer is siting on a jack, so the tyres will look tucked.
Vehicle: Sj70 tintop
Post Posted: Tue Nov 04, 2014 4:06 pm
Geez Joel, that comment was from a long way back
bwhahahah im not getting any better am i??
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Jan 23, 2015 10:06 am
So, i have moved house, got a girlfriend, helped her move, been on a months holidays and started a new job that's been demanding 10+ hours of "for love" overtime.
as such this the first update in a very long time.
trailer now has a fully locking rear door with 3 latches, and waterproof seals. have cut out the paneling for one side to glue on today if it stops raining.
Vehicle: 91 Tin Top
Post Posted: Fri Jan 23, 2015 11:23 am
Been wondering how this thing was going.
Figured the new job was keeping you busy. ;)
Good to see some progress.
Post Posted: Fri Apr 17, 2015 10:11 am
Is it finished now?
Nearly been 2 years sense you started the project :lol:
Post Posted: Fri Apr 17, 2015 12:21 pm
I thought this was going to be an update, damn you monley
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Apr 17, 2015 12:36 pm
lol
no. i need to connect the breaks and take it to the pits where they will probably tell met to piss off and get someone who can weld to re do the draw bar plates...
but actually other then those it is done, just need to stick reflectors on and get the jimny roadworthey so i can tow it to the pitts without them puting a yellow sticker on my car shortly after passing my trailer out...
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sun Apr 19, 2015 4:59 pm
lights working!
no guards yet. will have to cut a arch just big enough to remove a tyre at 40psi
and from the front
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu May 21, 2015 7:31 pm
I welded my safety chain on. No pic of the weld. ImageImage
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Aug 12, 2015 3:18 pm
it has a number plate!!!
Vehicle: 91 Tin Top
Post Posted: Wed Aug 12, 2015 3:38 pm
It would be sitting pretty level now with the Jimny lowered wouldn't it?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Aug 12, 2015 3:58 pm
yep. spot on. think the electric breaks need to wear in or something but, brake controller is making the volts but cant get them to lock yet...
Vehicle: 91 Tin Top
Post Posted: Wed Aug 12, 2015 4:15 pm
I found cable size was critical with the brakes working correctly.
The standard 7 core cable is useless, I had heaps of problems with the brakes on one side not working and the trailer pulling hard under brakes. It would actually lift the back of the Jimny and make it dive hard left.
I spent ages fault finding and testing the circuits. In the end I just ran new cables (the wires measured about 3.5mm diameter) from the plug to each drum and they started working perfectly.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Aug 12, 2015 4:57 pm
will check, think i might have 3 m of the old 7 core between the controller and the cars output plug....
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Aug 31, 2015 2:10 pm
Did the camping.
can call the first trip a success. will just have to put lock nuts on the number plate bolts (lost 1/4)
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Sep 01, 2015 8:13 am
and apparently some 'wiring issues'
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Feb 15, 2016 7:58 pm
Up For sale at the moment, but if I cant sell it, I might just keep it.
it makes camping too easy and is much more enjoyable then a swag.
