| Oztrail Camper 6 Custom trailer setup http://auszookers.com/forum/viewtopic.php?f=40&t=45835 |
| Author: | buzbox [ Sat Apr 12, 2014 10:45 am ] |
| Post subject: | Oztrail Camper 6 Custom trailer setup |
Just thought I'd do a very quick write up in this section of my trailer I setup a few years ago. Doing it this way saved me over $1500 than buying one already done. Oztrail Camper 6 trailer tent ![]() Standard 6x4 box trailer ![]() ![]() SPOA For it to sit level with the car ![]() Cut and welding on a longer drawbar and treg hitch ![]() ![]() ![]() Chopped off the side tie down rails. ![]() Swing out tailgate with gate hinges ![]() A brace from across the tailgate makes it square again as well as add's another mounting point for the tent ![]() Time to paint it in Charcoal hammertone. I also seam sealed any edges to stop dust and water getting in between any gaps. ![]() ![]() ![]() ![]() And the finishing touch ![]() Tent time and I also wired in some LED tail lights. ![]() ![]()
| Author: | jonno_racing [ Mon Apr 14, 2014 12:57 am ] |
| Post subject: | Re: Oztrail Camper 6 Custom trailer setup |
Oooow I wanted a blue tent! |
| Author: | zoukshin [ Mon Apr 14, 2014 2:41 pm ] |
Nice and quick. good stuff. |
| Author: | zukenutter [ Wed May 14, 2014 9:35 pm ] |
Great job. Our 6 is about 8 years old and still in great condition. Mrs ZN loves it. At 100kg it's quite light considering that it's equivalent to a good size tent, 6sq.m open covered awning area and mattress. |
| Author: | Marko_SJ [ Fri May 16, 2014 4:42 pm ] |
Very jealous of the setup. Nice work. |
| Author: | zukenutter [ Fri May 16, 2014 5:11 pm ] |
Ha! I just noticed the Vitara badge, nice touch |
| Author: | shep [ Fri May 16, 2014 7:37 pm ] |
I wish they made the 6x4 tent to match a 105cm high trailer |
| Author: | zukenutter [ Fri May 16, 2014 9:14 pm ] |
Mine's at full stretch when set up on firm ground but on soft sand and aired down it work well but I don't think my trailer is that high. |
| Author: | shep [ Fri May 16, 2014 9:26 pm ] |
Yeah they just make them to fit a 85cm high trailer. |
| Author: | zukenutter [ Fri May 16, 2014 9:30 pm ] |
I pre measured a 6 on display at a camping store, built my trailer to the right height then did SPOA. |
| Author: | jonno_racing [ Thu May 22, 2014 1:23 pm ] |
yeah my trailer is 2 high... the bottom ends up wonky ish! |
| Author: | buzbox [ Thu May 22, 2014 1:44 pm ] |
Another alternative is to take it to a canvasser and get the base lengthened to suit what ever height you want. Oh also, Not much of an update, but It got me thinking, I don't have a spare, and don't really want one. So without going for a 4wd AT or mud tyre, What is a good tyre that is puncture resistant, Is close to the size of a regular tyre and will comfortably fit under the guards.. So I picked up some used Pirelli Rally tyres If they go flat, the sidewall is stiff enough to keep driving and the aggressive tread pattern makes sure it doesn't slide around on dirt or muddy tracks |
| Author: | just_cruizin [ Thu Jun 05, 2014 7:46 pm ] |
Just get some huds to suit the Vit that way you can run the same wheel and tyre setup |
| Author: | buzbox [ Thu Jun 05, 2014 11:22 pm ] |
The Vit is no more, but for new hubs = $ 100+ Used rally tyres, $0.00 |
