It is currently Tue Nov 03, 2026 7:31 pm
Vehicle: 09 Jimny Sierra
Post Posted: Tue Oct 28, 2014 8:06 pm
Hey guys, i have a trailer which is like 30+ years old, my family have re- done it god knows how many times, now ive started to use it. Get to the point , it has some gnarly rust holes , whats the best way to replace it? I can weld but i assume the steel would be expensive, i will be making it so i can use it better when i take my quad out and for camping, but my bros also use it for work, any sugestions?
Wolf jimny- made from 50% recycled goods
Vehicle: sj51
Post Posted: Tue Oct 28, 2014 8:35 pm
Timber floor
Vehicle: no vehicle
Post Posted: Tue Oct 28, 2014 11:08 pm
diamond plate ally
Sierras are cool. Jimny is cooler
Post Posted: Wed Oct 29, 2014 5:15 am
A Sheet of 2.9mm thick gal is cheap.
I would expect the merchant would sell a 24x12 sheet off the shelf for around $110 + GST
If you went to a small sheet metal place, they would probably even cut it to size for you if you order through them.
Post Posted: Wed Oct 29, 2014 9:22 pm
My work trailer has checker plate aluminium sheet, pain in the bum to sweep out compared to flat sheet, especially wet dirt.
Post Posted: Wed Oct 29, 2014 9:30 pm
I have some ply, but im not sure, might patch it
Post Posted: Wed Oct 29, 2014 9:40 pm
I got a sheet of 2mm (I think) zink plated steel delivered to my house for $100. Cut out the old stuff, drop in the new floor. Couple of welds and will last another 30 years
Vehicle: 91 Tin Top
Post Posted: Thu Oct 30, 2014 3:37 pm
Mine is 2mm gal plate. Use either Gal or zinc flat plate.
Checker plate is a pain to sweep clean as noted above, but more importantly, that stuff scraps the hell out of the bottom of your esky when you drag it in and out while it's full of beers... ;)
Post Posted: Sun Nov 02, 2014 10:58 am
can also flip the checker plate over and use the bottom as the top
Post Posted: Sun Nov 02, 2014 12:47 pm
I would just grind the bumps off, then it wouldn't need to be flipped ;)
Users browsing this forum: No registered users and 12 guests
