It is currently Tue Nov 03, 2026 1:50 pm
Vehicle: Suzuki Jimny 2010
Post Posted: Mon Jan 24, 2022 2:49 pm
I checked the transfer box, and my little pinkie could not find any oil. Oh well, may as well drain and refill.
Checked the quantity required, 0.8L so bought a 1.0L in the squeeze pack. Easy to use.
Ended up slowly putting the whole 1.0L in waiting for it to dribble out the filler hole. No, it never did, and still can't find any oil on my pinkie. It is jacked up a LITTLE in the rear so I will check again when it's back on the tyres but I'm a bit sus now. Anyone else found it takes more than 1L???? Maybe I have the wrong spec on quantity?
'10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Post Posted: Mon Jan 24, 2022 4:39 pm
How much more did you add before it came out the fill hole?
Post Posted: Wed Jan 26, 2022 12:15 pm
I had only 1L, so it has 200cc over the nominated fill quantity atm. I won't add more till I check it when dead level, and then only if it is recommended.
Users browsing this forum: No registered users and 13 guests
