It is currently Thu Oct 15, 2026 10:34 am
Post new topic Reply to topic  [ 232 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8
Post Posted: Tue Apr 20, 2010 3:16 pm
not another UFP! :cry:
un finished project
Post Posted: Tue Apr 20, 2010 4:36 pm
yep sure is another
WBF
whining bitching female.....
sad to see it go, but i have hardly any time as it is let alone finding time for the zook.
anyway, my loss some one elses gain.
Web wheeler extroadinaire
Post Posted: Tue Apr 20, 2010 5:47 pm
GROWBF
Get rid of wbf.
Times too short to waste with whingers.
Post Posted: Thu Apr 29, 2010 1:38 am
keeping the zook and the Mrs.
did some work on the chassis to make way for the new steering box on the weekend. and in the process of making up the plate to strengthen the chassis ext and mount a winch off.
Post Posted: Tue Jun 01, 2010 10:37 pm
high steer set up thanks to joe blow's idea.
muchly appreciated.
Post Posted: Tue Jun 01, 2010 10:39 pm
its the same arm that is sitting underneath it, simply flipped and bolted down.
i dont have access to a mill to machine the two mating surfaces flat as joe does, so i used spacers made from 20mm round bar. just so happened to have some stainless bars machined up with a pilot hole lying around...
drilled them out to suit and away we go.
Post Posted: Tue Jun 01, 2010 10:46 pm
You only have to ask me :wink:
Post Posted: Tue Jun 01, 2010 11:20 pm
do you guys have power out there??? i thought you were always on your solar powered phone on here???
thanks mate, i'll keep you in mind.
Post Posted: Tue Jun 01, 2010 11:28 pm
Buhahahahaha. yeeeah hawwww cowgirl.
We have a Pedal Power Printing Press.
Post Posted: Sat Jun 05, 2010 6:56 am
g'day mate. there are pics of my anti wrap bar in my build thread. http://www.auszookers.com/index.php?nam ... pic&t=8941
drag link is the bar that joins the two front wheels/swivel hubs togeather to keep them pointing in the same direction.
body lift will be fine with hilux diffs. you will need if for 35's. i have 34's at the moment with body lift and have spaced the front diff forwards 27mm and it still rubbs in the guards on full lock.
i dont think you will need extended shackles with SPOA but if you can i would suggest doing a 3/4 elptical in the rear. cheap and works a treat.
Sierra, Ute Chop, Tube Tray, 1.6 EFI, locked F&R,
Post Posted: Mon Jun 07, 2010 1:57 am
35mm body lift bolted in already. diff is forward 200 mm with huge offset and plenty of guard cutting, have not flexed it up as yet, so im nto sure where/ how much it will rub.
wont be using extended shackles.
i plan on extending out the rear chassis to use the same springs as the front and move the diff back 160mm.
next on the list is to fold up the plate for the front of the chassis so i can bolt up the steering box and mount the darren hinch.
Vehicle: MY2019 Jimny
Post Posted: Sat Jun 12, 2010 10:32 am
Yay the build continues!!!
Users browsing this forum: No registered users and 367 guests
