It is currently Sat Sep 19, 2026 12:43 pm
Post new topic Reply to topic  [ 1017 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 34  Next
Vehicle: Vit swb 95
Post Posted: Sun Oct 28, 2012 6:36 pm
Really depends on the price then... What about the side wall on both? one better then the other?
Post Posted: Sun Oct 28, 2012 6:46 pm
In the construction or the grip?
Vehicle: Vit swb 95
Post Posted: Sun Oct 28, 2012 6:47 pm
Both?
Post Posted: Sun Oct 28, 2012 6:51 pm
I'd imagine construction is the same as Bighorn. And grip.. they're both kinda small. Bighorns have little blades, Treps have little staggered squares.
Much of a muchness really..
Post Posted: Sun Oct 28, 2012 6:54 pm
both are good tyres and great value imo
Post Posted: Sun Oct 28, 2012 6:56 pm
Yep ^^
Post Posted: Sun Oct 28, 2012 8:38 pm
agreed, been running mine for 25 thou. great value and would be them again in the 762 if i could.
Vehicle: Daisy
Post Posted: Sun Oct 28, 2012 9:02 pm
Can someone explain how backspace and offset work? Please?
I've been searching for wheels for most of the week and myself and Anto86 can't work out what the hell is going on with some of the measurements quoted on wheels.
As we understand it, backspace is from the inside edge of the rim to the mounting surface.
Offset (in our case negative offset) is how far from the centre of the rim the mounting surface is, with negative being a shift inboard with the mounting surface and positive being a shift outboard.
Now I get to the question, I completely understand when I look at Dank's thread about the kpd beadlocks being an 8 inch wheel with -25mm offset which creates 3 inches of backspace. That works out and it's easy.
What I can't understand is how 7 inch procomp -38 offset wheels can have 2.5 inches of backspace. Because 7 inches of rim, take away 2.5 inches of backspace, leaves 1 inch to the centre of the rim which would be a -25 offset not -38 as stated.
Are we getting the maths wrong? Are the tables wrong? All -38 offset 7 inch wide wheels are quoting a 2.5 inch backspace so I must be calculating something wrong.
If anyone knows what the hell is going on here let us know!
http://www.procomp.com.au/Default.asp?MenuId=WHEEL_0052
15x7 5x5.5 -38mm 2.5" backspace WTF?
Thanks in advance.
Vehicle: LJ20 LJ50
Post Posted: Sun Oct 28, 2012 9:36 pm
Thanks in advance.
Did you forget about the 12mm of steel ( not 12mm of steel but with pressing some shape and wheel stud hole bit) that they need for the centre???? 13mm = 1/2 inch. Its not the centre of the centre its the bolt up face to the rear of the rim
Camels have nice toes
Vehicle: Daisy
Post Posted: Sun Oct 28, 2012 10:25 pm
No I didn't forget about that bit, I was hoping I did but I still can't make it work, from the bolt up face to the rear of the rim they say is 2.5" backspace. Which would then have the bolt up face 1" from the dead centre of the 7" rim (3.5" halves) which is clearly not -38mm of offset.
OR am I still doing it wrong? 2.5" backspace would be -38mm on an 8" rim because it would have the extra 0.5" between the bolt up face and the centre of the rim, but it just doesn't add up for a 7" rim/wheel...
Post Posted: Sun Oct 28, 2012 10:39 pm
Backspace Method: Measure from the extreme rear edge of the rim to the hub mounting face. Distance "A" in millimetres.
Centreline Method: Measure the overall width of rim (Distance “X”), halve this measurement to find centreline then measure backspace (Distance “A”).
Subtract “B” from “X/2” and you now have the centreline offset, which in Australia is written 35P or 10N to denote either positive or negative centreline offset. In Europe, centreline offset is usually written ET35 or ET-10 etc.
NOTE: The centreline offset measurement is “rim width dependant”, ie. as the width of the rim changes, so does the centreline offset, eg. if you have 14 x 6 wheels with 47P offset and would like to fit 14 x 7 alloys with the same backspace, then the same offset in 14 x 7 is 35P. In both instances, the backspace remains at 135mm.
Vehicle: Daisy
Post Posted: Mon Oct 29, 2012 6:57 am
Yep I've got that part down but can someone else confirm the missing half inch???
Vehicle: LJ20 LJ50
Post Posted: Mon Oct 29, 2012 7:22 am
Okay my last post was wrong
Look at backspace. It is to the back of the rim.
The 7 inch part is measured at a different point. It is measured where the tyre bead sits not the extreme parts of the rim
Off set is the point the bolt up face is away from the centre line
Vehicle: Daisy
Post Posted: Mon Oct 29, 2012 8:45 am
Yes this is what I was trying to find out! So the 7" rim is actually a little wider physically but the bead seats are 7" apart, this accounts for the difference, cheers for the help!
Vehicle: TBA
Post Posted: Fri Nov 02, 2012 4:54 pm
Browsing in Costco on the way home today I found D697 Duelers in 205/70/15 for $538 a set of 4 fitted after discount, anyone know if any other tyre retailer will come anywhere near that?
They seem like a good enough tyre for some semi regular forest fire trail bush bashing? No beach, all bush but also commuting 25km a day.
And Costco do puncture repairs for the life of the tyre and a free balance and rotate every 10,000km.
Cheers,
Tony
Vehicle: Vit swb 95
Post Posted: Wed Nov 07, 2012 4:36 pm
I can get 4 x Micky Thompson MTZ's 31"x 10.5 x 15. Have approx 30% tread left for $150 total...
I currently have 235/75/15 AT tyres.. are these worth getting just for offroad use?
Post Posted: Wed Nov 07, 2012 4:43 pm
no, they are a shitty tyre
Vehicle: Vit swb 95
Post Posted: Wed Nov 07, 2012 4:46 pm
It will only be for a little while tho, before i get bighorns or Treps...
So they wont be any better then the AT 771's ive got now?
Post Posted: Wed Nov 07, 2012 4:50 pm
with 30% tread your ATs will have more tread depth, save your money
Vehicle: Vit swb 95
Post Posted: Wed Nov 07, 2012 4:58 pm
I have 6-7mm tread on my ATs and 0 side biters
Vehicle: Vit swb 95
Post Posted: Wed Nov 07, 2012 5:03 pm
And was just told that these tyres have around 6-7mm tread aswel
Vehicle: Vit swb 95
Post Posted: Wed Nov 07, 2012 5:07 pm
Here are some pics..
For $150 for 4...
Whats so bad about them Tanshi
Post Posted: Wed Nov 07, 2012 5:12 pm
i'd buy them for $150, you can't go wrong... if not i'll give you money for them & i'll run them on my trailer
the micky T's are renown for having wafer thin sidewalls
Vehicle: Vit swb 95
Post Posted: Wed Nov 07, 2012 5:21 pm
I cut an AT on my first biggish trip with them brand new.... side walls suck balls...
Ill only get them to fit for about... 3months..
I mainly want them for trimming my guards and to see how my car goes with 31's (gearing ect)
Ill give you them for free atari when i get the new tyres? These will only be use when i go offroad... Some ill maybe only use them 4-5 times hahaha
Vehicle: Vit swb 95
Post Posted: Wed Nov 07, 2012 5:22 pm
2 Questions tho..
1. Will my 235/75R15 fit on stock rims?
and
2. Will i fit 4 31's in the back of a swb zook...
Post Posted: Wed Nov 07, 2012 5:24 pm
cheers sam, i reckon i'll probably have sorted a pair by then... really only need 2 or 3
1 yes
2 maybe
Vehicle: Vit swb 95
Post Posted: Wed Nov 07, 2012 5:34 pm
Haha alrighty, Might borrow a mates UTE then
i might have some 31" BFG at's coming up soon to (only 20% tread or so tho...)
Post Posted: Wed Nov 07, 2012 5:42 pm
If the BFG AT's are that low, don't do it! They're possibly one of the scariest tyres on a wet road with half tread let alone even less.
Post Posted: Wed Nov 07, 2012 6:33 pm
... and they roll of the rim like they're made of playdo at off-road pressure. Leave 'em alone.
You should get 4 31s in the car with the seats down. Leave your spare at home and bolt one on the back if it's too crammed (deflate it completely so it can sit on the bumper.
Vehicle: Twin cam 1300 gti engine.
Post Posted: Wed Nov 07, 2012 6:55 pm
After peoples opinions on Baja claws? Have been told they are not so good on the sides of hills, that they want to slide sideways because of thr tread pattern.
I'm looking at getting these in 31" for my sierra next.
Users browsing this forum: Google [Bot] and 114 guests
