It is currently Sun Oct 04, 2026 7:05 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Mon Jun 14, 2010 2:25 am
the system he is runnin is 850 supplied only i run the same ;)
it really is a nice ride,
Skuxx
Vehicle: Ducati Monster
Post Posted: Mon Jun 14, 2010 3:02 am
jord, well its always he thought that counts LOL
Post Posted: Mon Jun 14, 2010 8:06 am
Fatchickscantjump wrote:
5ierra wrote:
I get this with 2" kings, Boge shocks and stock shackles.... thats not full flex either.
whered you get this system from..... not the logan suzi service centre did you?????
i got the exaqct same kit,
do you still have the load leafs in,
i ha ve a SWB and i dont get as much flex as this your lol,
your doing well.....
Argh, my sway bar isnt on there, dunno why i thought it was :S
Ok, so my set up is...
2"King Springs
Boge Shocks
Nt Chassis with wide track difs*
2" bump stop extensions
*this is the reason mine flex so well, my springs are closer together so there is a larger force pushing my tyre down while flexing.
Post Posted: Mon Jun 14, 2010 8:52 am
2"King Springs
Boge Shocks
hey nice ride
Could you or anybody with flex like that measure the lenght of the springs (along the curve from the middle of the bolt holes)
i know its a pain but it would help out lots.
thanks aleks
Vehicle: LJ50V, SJ70
Post Posted: Mon Jun 14, 2010 10:11 am
Jccck wrote:
Have you thought about bumpstop extensions?
Usually the bumpstop will act as a lever to force the other wheel down further
What a load of shit, ......
Have a look at Zuki's pic in the June Photos thread, and notice the shackle angles on the front springs. How much longer do you suggest he makes his bumpstops to improve the flex of his suspension? (PS not having a go at Zuki; that's an awesome shot!)
Post Posted: Tue Jun 15, 2010 12:42 am
I received an email from King Springs and for Raised springs the following Part no's are Suz-002 (front) & SUZ-006 (rear).
Please note that this is for a SWB Sierra.
RRP is $205 (incl GST) per pair front
RRP is $291 (incl GST) per pair rear
Distributors include:
Autobarn, AutoPro, Checkpoints, Fulcrum, Repco, Supercheap, Bursons & most leading suspension specialists.
Post Posted: Tue Jun 15, 2010 1:49 am
is this and good for a sierra ? flex wise
Vehicle: WT Tinny, NT lwb, 1L lwb
Post Posted: Tue Jun 15, 2010 2:46 am
My Grandma flex's more than that, and she's been dead for 5 years....
Looks good to me mate
JrZook - Mine only hangs 2.5".
 Profile WWW ICQ YIM
Post Posted: Tue Jun 15, 2010 6:55 am
hey
could you post a link i cant seem to find the thread
edit. pic found
Post Posted: Tue Jun 15, 2010 7:25 am
i have kings and hate them, im just put OME in the rear and doing ruf very soon :)
Post Posted: Tue Jun 15, 2010 7:46 am
i've just got cheap $550 dollar ebay springs, 2 inch lifted, 2 inch lifted hilux rancho shocks, and spoa, and i reckon i've got more than enough flex.
Post Posted: Tue Jun 15, 2010 7:59 am
Zuki's car actually flexes fine just the front end is unloaded in the uphill shot. And yair ... can't see bumpstop extensions doin much there.
Post Posted: Tue Jun 15, 2010 8:13 am
I think the reason why on mine is that my shocks are out of travel, they are fully extended in that shot.
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Tue Jun 15, 2010 8:14 am
My shocks are nowhere near long enough that is why my shackles are like that. The shock is holding them in that position.
Zuki
Now just drive i
Post Posted: Tue Jun 15, 2010 10:45 am
finlay113 spoa makes a fair difference to the way they flex.Does look pretty good tho
Post Posted: Tue Jun 15, 2010 11:46 am
If we're talking fulcrum points and how they influence flex, Narrow Tracks have more apparent flex than Wide Tracks (and an LJ50 Vs LJ80) because both have the leaf spring mounted closer to the centreline of the vehicle. If the spring is able to flex a particular amount through compression under the weight of the corner of the car, or droop with the weight of the tyre/wheel (let's say 4 inches of travel), if that spring is closer to the centre of the vehicle it allows more articulation at the wheel. NTs with WT diffs rock!
Post Posted: Wed Jun 16, 2010 7:43 am
So an LJ50 with wide track diffs should rule then ,(or is it roll) :lol:
Post Posted: Wed Jun 16, 2010 8:18 am
Haha, thought of that but it looked too hard to get the chassis rail and the diff centre in pretty much the same spot.
Post Posted: Wed Jun 16, 2010 8:21 am
Look harder :D
Post Posted: Wed Jun 16, 2010 8:25 am
Look harder :D
both long side's of a n/t diff glued together.. :roll: :wink:
Post Posted: Wed Jun 16, 2010 8:29 am
steknig wrote:
Look harder :D
LOL :D
WT's in LJ50 is worth the effort IMO.
Post Posted: Wed Jun 16, 2010 8:31 am
Um, it work's !!!! :roll:
Post Posted: Wed Jun 16, 2010 8:53 am
Spring pad spacing on an LJ is the same as a NT sierra, so chassis clearance isn't the problem. Diff offset re the transfer is an issue, but not a big one.
Post Posted: Wed Jun 16, 2010 9:01 am
LJ50 spring spacing is 50mm inboard of LJ80 (each side). Also LJ chassis have the rails closer together. We have put 1 litre housings into LJ80 chassis to move them, seem to remember the centre would get close at best to the rail on articulation. Prefer the travel from the LJ50 spring and shock spacing though.
Post Posted: Wed Jun 16, 2010 9:13 am
Fair point - I was looking at an 80 and noted chassis width in the front as the same as a sierra.
Post Posted: Wed Jun 16, 2010 11:54 am
LJ 80 and LJ 50 chassis rails are the same width as each other, the spring pads are diffrent as 3cyl said where as 1Lt rails are wider.. :wink:
Post Posted: Sat Jun 19, 2010 7:01 am
Just doing some testing down the back yard this arv' the LJ50 is still under construction, checking for clearance since this time I've left out the body lift for stability. It's an example of LJ50 spring spacing with LJ80 track. Chassis is basically stock, springs are recycled and cambered widetrack Sierra and shocks are monroe gas second hand off a Daihatsu which a mate gave me. Still need to do the exo cage and front bar.
Post Posted: Sat Jun 19, 2010 7:12 am
Wayne it's coming along nicely, did you get a pic of it sitting on the flat? The front is working heaps good, compared to the rear or it just the camera angle?
I know it has been a while building.... but how long before it's ready to wheel.
David
Zuki
Now just drive i
Post Posted: Sat Jun 19, 2010 7:23 am
I'd say a couple of weeks David, but then I have said that before haven't I? The running gear is off the white one which always had more travel in the front than rear (front springs are closer together). So how's Heath's new rig going?
Edit: Didn't throw in this rear shot cause it's crap, there's some rear travel but more in the front.
Post Posted: Sat Jun 19, 2010 7:34 am
Yeah I think it is going ok! He has spent a fair amount of money on it and he is getting the broken engine mount done next week along with turbo getting boosted and retuned. He is getting a new front bar and Safari Snorkel. and the list is not getting smaller of what he wants to do to it.
Zuki
Now just drive i
Users browsing this forum: Google [Bot] and 202 guests
