| Author |
Message |
appsie
 Posted: Mon Jun 28, 2010 8:25 am |
arch is giving you the lift.
length is giving you the flex and a shagged leaf pack that sits flat always works a treat there too.
alien
 Posted: Mon Jun 28, 2010 9:02 am |
yep - definitely... well, kind of...
a more arched leaf will give more compression than it will droop. so your uptravel will be greater than your downtravel - which in a zuk is kinda backward to what you want, as once you go a larger tyre theres not much room for uptravel! (bump stops, wheel arches and shock placement are an issue).
a flat leaf gives 50/50 up and down travel, only limited by your bumpstops on the up travel and shocks and eventually spring length on down travel.
So, a flat, long leaf is the best for our application. This is why mines SPOA on the lux fronts. the SPOA provides the lift that the leaves no longer give and allows clearance for the up travel.
The only other way to achieve this would be a virtual lift on the front end (given the rear is being tray'd) all the way to the bonnet - but even then theres still the issue of shock placement and finding the right ones.
THENNNNN after all that, in SPUA configuration the extra length of the hilux front leaf up front makes for a pretty bad approach angle.
What im saying is, personally i think leaves that long should be done SPOA and all work along the way checked by an engineer for safety and quality.
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Mon Jun 28, 2010 9:14 am |
I just clicked on this thread thinking it was the build up for the LWB nicknamed "spring onion"
Alien your explanation has explained leafs to me awesomely. in a couple of months I was going to ask a noOb question to explain the basics of how it all worked.
cheers
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Mon Jun 28, 2010 9:53 am |
alien wrote: a more arched leaf will give more compression than it will droop. so your uptravel will be greater than your downtravel - which in a zuk is kinda backward to what you want, as once you go a larger tyre theres not much room for uptravel! (bump stops, wheel arches and shock placement are an issue).
I disagree, a spring with more arch won't compress more. They are generally a lot stiffer to maintain the height and don't compress much at all. Thus you would get a lot less travel then out of lesser arched springs.
This is the one and only advantage to Spring over in my opinion, you get lift but can run flat springs.
For my build I'll be getting 300mm longer then standard springs. Track bar is a certainity. Rear axle will be 150mm rearwards.
alien
 Posted: Mon Jun 28, 2010 10:18 am |
^^ true, but if he's chucking a 3" lifted leaf in with load leaf removed it'd still be pretttty soft. But basically thats another good point not to run a lifted leaf in this application (super long).
just_cruisin - if you're moving the rear back 150mm (the added length of the leaf) what are you doing up front? I moved my front forward more than my rear back so that the engine weight (and mine) was more central, as the rear has near no weight in it. My rear is back about 1", as i've not done a chassis extension at the back, just got the rear shackle hanger right on the end of the chassis, then the shackle pokes out from there.
here's a gratuitous image:
and a flex shot:
just_cruizin
 Posted: Mon Jun 28, 2010 10:30 am |
I'll be full ruf, but mines on a LWB chassis with tube tray.
Everyone is pushing me to go links but I want to this one simple at this stage. Mind you by the time I do anything petrol won't be available, I'll have to wait for the BP oil slick to reach OZ and brew my own.
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
royce
 Posted: Mon Jun 28, 2010 10:32 am |
I dont see any link at all between shape of a spring and how stiff it needs to be to hold it, ive had low springs fail in a day and tall springs last years with not a great difference in spring rate
a spring will travel down until you are at teh point where the shackle wont rotate any further towards the diff, regardless of what camber the spring sits at, if yours dont do they you have something stopping it, likewise the rate will effect it compressing, gets hard to work on a sierra as you end up a bit soft
just_cruizin
 Posted: Mon Jun 28, 2010 10:39 am |
The straighter the peice of steel the easier it is to bend. Yes you can get a 3" spring with a good spring rate but the eyes would be nearly touching eachother in order for it to give a 3" lift under load. Not much point in making a spring you need to load up to install.
chris_mac
Joined: Sat Aug 23, 2008 11:30 pm Posts: 283 Location: Sydney
 Posted: Mon Jun 28, 2010 11:42 am |
from memory you can use CJ springs, they are as long as YJ but 50mm wide (as sierra), you might get some old ones from jeepies
lux and YJ or ferroza springs are wider hence more mods.
supposedly with YJ kit you don't need a trackbar, because of the extra strength in wider springs, Suziblue order or was about to do it YJ kit from Rocky Road for his LWB. Maybe ask him.
alien
 Posted: Mon Jun 28, 2010 12:28 pm |
its still a longer spring so will need new mounts, but not perches (unless you're going SPOA).
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Mon Jun 28, 2010 9:09 pm |
No SPOA - wanna copy Suzy, she is low and stable.
chris_mac
 Posted: Tue Jun 29, 2010 12:10 am |
In this case I would think of buying spring under YJ kit from Rocky road. Bolt on. no need to cut anything, all needed hardware Ubolts, spring plates etc. You can by OME YJ springs from ARB localy. They are 2" lifted so compering to standars zook springs you would have 3-4" lift from springs. no need to extend the chasis, wheelbase extended slightly. Anyway it's a point of view from someone who don't have a welder and can't weld:)
zukmeista
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
 Posted: Wed Jun 30, 2010 6:12 am |
chris_mac wrote: In this case I would think of buying spring under YJ kit from Rocky road. Bolt on. no need to cut anything, all needed hardware Ubolts, spring plates etc. You can by OME YJ springs from ARB localy. They are 2" lifted so compering to standars zook springs you would have 3-4" lift from springs. no need to extend the chasis, wheelbase extended slightly. Anyway it's a point of view from someone who don't have a welder and can't weld:) Exactly why I suggested it in the first place. Minimal fabrication and probably easier to engineer too.
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Wed Jun 30, 2010 6:16 am |
zukmeista wrote: probably easier to engineer too.
I wouldn't say that.....  nothing is easy these days.....
_________________ 2013 GV 1998 SV420 ute
alien
 Posted: Wed Jun 30, 2010 8:14 am |
^^ especially bolt on things... engineers (well mine) like welding, and lots of it, with gussets and lots of them, and fisch plates... he loves those.
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9717 Location: NSW
 Posted: Wed Jun 30, 2010 1:04 pm |
Mr Linc.
Spua:
Sierra springs as Ruf has a bad enough approach angle.
Hilux springs are going to make it mega worse.
If i wanted lux springs:
Flat Hilux springs. Spoa. No BL.
lump_a_charcoal
 Posted: Wed Jun 30, 2010 1:24 pm |
OK maybe Sierra rears up front, hilux fronts in the back? That would work out cheaper, as I have rears already. Would also negate the need to remake a couple of hangers..
Is your approach angle all that bad Tim?
BlueSuzy
 Posted: Wed Jun 30, 2010 1:31 pm |
It is cos my shackles are double size.. Rockclimbing, i always hit them.
If you ran smaller shackles like most on here, it will be betterer.
I used to hit my stock shackles with stock springs and stock tyres. Bending springs is so awesome..not..
Fatzook
 Posted: Wed Jun 30, 2010 1:36 pm |
lump_a_charcoal wrote: OK maybe Sierra rears up front, hilux fronts in the back?
This is my setup.
lump_a_charcoal
 Posted: Wed Jun 30, 2010 1:40 pm |
Timmay, turn on messenger.
lump_a_charcoal
 Posted: Wed Jun 30, 2010 1:41 pm |
Also, tell me why inverting rear shocks leads to more travel? Is inverting them turning them upside down, or moving the tops inwards?
alien
 Posted: Wed Jun 30, 2010 1:45 pm |
inverting is upside down isnt it?
laying them over is done cos theres no room for shock towers in the rear (you will have room though cos yours is a trayback!).
lump_a_charcoal
 Posted: Wed Jun 30, 2010 1:50 pm |
Yeah that's what I thought, but I couldn't see why you would get more travel.
alien
 Posted: Wed Jun 30, 2010 10:43 pm |
not unless clearances are so tight that the body of the shock was hitting something, and inverting it means it clears the thinner tube? lol but thats still only around 10mm difference.
5ierra
Joined: Tue Mar 09, 2010 10:30 pm Posts: 1645 Location: Ipswich
 Posted: Thu Jul 01, 2010 12:51 am |
Fatzook wrote: zukmeista wrote: probably easier to engineer too. I wouldn't say that.....  nothing is easy these days.....
Not true, got my engine and seats done... longest part was putting the plate on... he didnt even start the car. No shit it took him a grand total of about 2min to say yay or nay. haha.
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Thu Jul 01, 2010 1:04 am |
our engineer is awesome though
lump_a_charcoal
 Posted: Thu Jul 01, 2010 1:06 am |
Hey guys, debate your engineers opinions elsewhere, I am trying to get some info here.
tanshi
 Posted: Thu Jul 01, 2010 1:11 am |
lump_a_charcoal wrote: Yeah that's what I thought, but I couldn't see why you would get more travel.
Laying them over or inboarding, allows you to get more shock length in, therefore allowing for more travel
lump_a_charcoal
 Posted: Thu Jul 01, 2010 1:19 am |
Yeah, but that isn't inverting them.
tanshi
 Posted: Thu Jul 01, 2010 1:36 am |
I think when people some people say inverting, they mean inboarding.
