It is currently Thu Oct 01, 2026 10:03 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
Vehicle: Suzuki Sierra
Post Posted: Thu Aug 05, 2010 9:52 pm
fuel pump relay on the fritz? :?
Will check it out. :idea:
Post Posted: Thu Aug 05, 2010 11:34 pm
Gee you have pretty much changes near everything!!! What are the computer grounds/wiring like? That jump starting thing sounds scary tho, hopefully it hasn't damaged the computer :? . Dunno how it was jump started but when i do it on any EFI car I like to turn the headlights on to try and suppress any high voltage spike from the alternator instead of the ECU.
So im assuming this issue happen on both a hot or cold engine?
Dan
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Fri Aug 06, 2010 12:42 am
Dan
Today we are doing the following:
Checking to see if the cam belt has skipped a tooth
Borrowing a computer from a wrecker ( thanks guys www.suzukispares.com.au )
Waiting for the EFI specalist to arrive.
Post Posted: Fri Aug 06, 2010 3:49 am
OK update:
Computer changed - still the same
Fuel pressure checked at rail at different RPM - all fine
Cam timing checked, no problems there either
FARKING BLOODY FARKING CAR!!!!!!!!
Post Posted: Fri Aug 06, 2010 4:45 am
sierrajim wrote:
OK update:
Very weird? What the wiring like? Quite neat? Battery and alternator condition? Injectors been cleaned and tested?
Dan
Lil Foot!
Post Posted: Fri Aug 06, 2010 7:38 am
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
OK, now if you have a Jimny head on your car and you roll it you might have issues with the fitting that the MAP sensor attaches to.
It seems to be some form of valve that screws into the inlet manifold. It had oil in it, bypassed it - no issues.
WOOOO BLOODY HOOOO
(Yes, I'm a happy man)
Post Posted: Fri Aug 06, 2010 8:25 am
YAY!!!!
Jimny head on a baleno block? :?
Post Posted: Fri Aug 06, 2010 8:33 am
Er, I think it's Jimny injection (computer) and manifolds on a distributor Baleno short block with a jimny cam wired into a Vitara TCC running a Vitara AW-4..... from memory :D
Well done Jim :D
Steve
Post Posted: Fri Aug 06, 2010 8:34 am
Thats seems like the long way around :roll: :D Good memory 8)
Users browsing this forum: No registered users and 111 guests
