It is currently Fri Sep 25, 2026 11:10 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Post Posted: Thu Dec 09, 2010 7:20 pm
go measure the front konis!!!!!
Post Posted: Thu Dec 09, 2010 8:29 pm
But doesn't that mean that I have to pull things appart? :? :cry:
Post Posted: Thu Dec 09, 2010 9:20 pm
just jack it up and tape from the top strut bolt to the bottom of the top mount would do :)
Post Posted: Thu Dec 09, 2010 9:21 pm
Fine. I'll bodge up a measurement for you :wink:
Post Posted: Thu Dec 09, 2010 9:29 pm
+/- 2.3mm will be good enough
Post Posted: Fri Dec 10, 2010 2:51 am
shandy92 wrote:
flatcat_auz wrote:
Dobinsons springs with Bilstein Struts.
how much are a set of bilstein struts? and whats the advantage with them?
http://web1.carparts-cat.com/default.as ... 02&31=4097
They are the best suspension set-up that I have experienced and can not mention one fault with them.
Oh other then the price. But inmo well worth it.
According to this website 190eu=$225 each.
Post Posted: Fri Dec 10, 2010 4:50 am
Struts.
Koni # 8741-1394SPT 537mm open - 378mm closed.
Rear shock
Koni # 8040-1106SPT 460mm open - 287mm closed.
I have already discussed the ide of a cusom strut that takes a replacable cartridge using the OEM leg. I would have to supply these on an exchange basis though, as they cannot supply OEM leg, or Koni leg.
Post Posted: Fri Dec 10, 2010 5:05 am
fronts seem ok travel from memory of OME' what point are those emasurements taken from?
Users browsing this forum: No registered users and 173 guests
