It is currently Tue Sep 29, 2026 9:31 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2
Vehicle: 75 Cruiser
Post Posted: Mon Nov 26, 2007 1:17 am
yeah, we were making jokes about this, .... when we fill it up, it's half a tank :lol: :wink:
Vehicle: 75 Cruiser
Post Posted: Sun Feb 10, 2008 12:40 pm
just to add some info to this thread, here's some pics of another rear winch set up.
Vehicle: 75 Cruiser
Post Posted: Thu Mar 20, 2008 9:56 pm
I made a new bracket to accommodate the new poly blocks which are copies of the above aluminium block. If the poly blocks fail i'll put the aluminium block in. Bruce has copied the block and we are going to test the poly out with plasma rope. You can't use these for steel cable.
The poly block has rear and side support, so it's not relying on the structure too much, but mainly uses the poly surface.
Post Posted: Thu Mar 20, 2008 10:17 pm
jeez, getting flash stevo :lol:
Vehicle: 75 Cruiser
Post Posted: Thu Mar 20, 2008 10:40 pm
yer, except for the bit of star picket welded to the panhard rod :oops: :lol: (been there since the last trip to Janowen Hills)
Post Posted: Thu Mar 20, 2008 11:54 pm
I'll be keen to know how this works out as I need a solution for when I put the winch under the tray.
Post Posted: Wed May 18, 2011 11:44 pm
Grave dig :helloo:
Hey Steve, how did this rear winch setup turn out? Ya reckon it would work with a SWB with a full body? eg, not chopped into a ute.
Vehicle: 75 Cruiser
Post Posted: Thu May 19, 2011 4:24 am
oooo gees an old one,
Damo, it worked out well, i have had it the same since this and used it quite a few times. The Poly block didn't work though, the rope ate away at it, i use the original aluminium one and it's good.
yeah you could stick it inside your swb rear end, but you'd want to mount it to the chassis and not the body ofcourse :lol:
Post Posted: Thu May 19, 2011 9:34 am
I have read a few threads and seen some pics of race cars doing this and I think it would be a great set up if done well.
Im pretty keen to make a set up on my car that Im doing now but I havent figured out how to do it without cutting the car into bits!
I also have an styleside LWB.
Plenty of room tho!
Im pretty sure gwagen has set up a LWb cab with a highmount in the back but it of course doesnt have the floor to worry about, being able to mount it under a tray.
Post Posted: Fri May 20, 2011 12:13 am
Hey Steve do you think it would be easier to do with a lowmount?
That way when it spools on the drum it wouldnt have the amount of rope to try and go on the drum without bunching??
Post Posted: Fri May 20, 2011 12:17 am
I think that unless you have a ute with a tray a lowmount is certainly the way to go.
Post Posted: Fri May 20, 2011 12:23 am
I have a LWB with tub and I already have a 60L feul tank mounted up through the floor in the very back and its bobbed also, so Im running out of room a bit..
Post Posted: Fri May 20, 2011 12:27 am
The major advantage with this idea is that if you try and winch up a bank, it will lift the nose.
Post Posted: Fri May 20, 2011 12:34 am
I would have thought that it wouldnt matter where the winch was it will be where the fairlead is mounted and cable exits?
Vehicle: Daisy
Post Posted: Fri May 20, 2011 12:46 am
Without doing the calculations I think it depends on your reference point.
It should be all about the fairlead position however what he's getting at is that the extra distance between the winch and fairlead moves the load and end points around (in the calculations) which gives a different force on the fairlead (and subsequent different "lift" to the front of the vehicle)
Simple example, get a piece of string (or the clothesline) tied off at one end, get a mass and hang it off the line really close to the loose end and see how hard you have to pull to get it to lift, then put it in the middle of the line and repeat. I haven't done the calculations but while I don't think it should change the force required, it probably does.
So yeh, not committing to either answer :p just explaining what I think he meant.
Vehicle: 75 Cruiser
Post Posted: Fri May 20, 2011 1:02 am
I did mine this way simply not to lose approach angle, and it also takes the winch weight from the front and puts in on the back, as you don't really have much weight on the back, most is in the front.
I use rope so even if it doesn't spool evenly it can bunch up a bit with out causing any issues. (it doesn't seem to bunch up though)
Vehicle: 75 Cruiser
Post Posted: Fri May 20, 2011 8:00 am
Here's my set up, photo is from when it was just done, 2007, gees that was a while ago..
We cut the fuel tank in half so there was plenty of room. Probably didn't need to but it makes for easy access to everything.
We cut the fairlead rollers in half so it's half the size of a normal one.
Post Posted: Fri May 20, 2011 11:35 am
Steve what distance would you think the winch is from the fairlead?
Did you set it up exactly like the white SWB?
Post Posted: Fri May 20, 2011 11:37 am
My bad you can see in the pic its set up in the middle.
so did you turn the rope at a 90 degree angle?
Vehicle: 75 Cruiser
Post Posted: Fri May 20, 2011 8:14 pm
The rope goes straight from the winch to the fairlead in the pic, which might be 30percent angle?, and then under the car, through a short guiding/protection tube, then to the front aluminium fairlead block.
The white swb set up has the rope going through the cab. Mine goes under the cab.
Post Posted: Sat May 21, 2011 9:22 am
So how did you weld on the tank without fear of explosion? I want t o put a vit pump in my carby tank,but do not want to go boom.
Users browsing this forum: No registered users and 173 guests
