It is currently Fri Oct 09, 2026 1:23 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2
Post Posted: Tue Dec 14, 2010 9:11 am
Yeah mate, if there a straight bolt in then your good to go :wink:
Post Posted: Tue Dec 14, 2010 9:15 am
You 110% require a mod plate for them, even if they bolt straight to the sierra runners or bolted straight into the floor mounts
the only time you might not need them is if you are fitting seats of a higher trim level from teh same model of car or something older than the ADR's for seats
QLD transport will give you a list of people in your area that can do mod plates, if you use proper grade 8,8 bolts and washers and nothing is dodgy its a simple process
Vehicle: Daisy
Post Posted: Tue Dec 14, 2010 9:34 am
I assume these two posts mean the same thing (taking note of the smiley at the end of the first post) I haven't been here long (auszookers) and it'll take a little while to get used to here, I'm just applying the salt similarly to OCAU and getting by, it's just that this is a little bit more serious given the fact that it'll void insurance e.t.c.
As usual, thanks again, I'lll call QT tomorrow and see if they can give me some names I can get a mod plate off.
Post Posted: Tue Dec 14, 2010 9:42 am
I read chopz' comments as if he were saying you don't need a mod plate if it bolts in :?
But I agree with Royce. If you change any component that effects emissions, safety or handling, with a non-standard part that was not found on any variant of the recipient vehicle, then you will need a mod plate. Period.
Check with your insurance company BEFORE you do the mod. They do state in the terms and conditions that any modifications need to be noted on the policy. They also reserve the right to cancel the policy if the modifications you have done are not covered by them.
Vehicle: Daisy
Post Posted: Tue Dec 14, 2010 9:49 am
At first I read it the same, then I noticed the wink smiley and reading the post after it by royce made me change my mind!
As you have said, I'll call the insurance company tomorrow as well, and the names QT recommends to find out what I have to do. I don't want to get stuck with some seats I can't use.
Vehicle: Daisy
Post Posted: Wed Dec 15, 2010 5:32 am
Bloody Thieves!
I called up the two names I was given by Queensland Transport to find out what I'd have to do to get the new seats certified.
The first guy said $330
The second guy said if it's done properly and no problems then $250 if it needs a re-inspection then that would take it up to $350
Queensland transport say you need two mod plates, an LK1 and an LK2.
Does anyone know anyone on the gold coast who would do it cheaper? I know it's a lot of responsibility for them to assess stuff, but seriously, that's like a licence to print money!
If nobody can help then I'll just do my best to repair the current ones, or get some second hand ones that are identical but not rooted.
Also, sorry about the double post, but it didn't seem like an edit would suffice.
Post Posted: Wed Dec 15, 2010 5:35 am
Teracis wrote:
Bloody Thieves!
The codes are right, but they should go onto 1 mod plate, as its being done at the same time. So is should be between $90 and $125.
Can't help you with any GC approvals sorry.
Post Posted: Wed Dec 15, 2010 5:38 am
my dude charges $70 per mod.
Post Posted: Wed Dec 15, 2010 5:40 am
There you go 8)
Vehicle: Daisy
Post Posted: Wed Dec 15, 2010 5:41 am
Where is your dude though? If he's on the Goldy or close by (Brisbane or Ballina) any chance of a number to call?
Post Posted: Wed Dec 15, 2010 5:46 am
Ipswich area I believe
Vehicle: Daisy
Post Posted: Wed Dec 15, 2010 5:57 am
Close enough to home, pm time I think!
Post Posted: Wed Dec 15, 2010 6:31 am
he comes to you :)
Post Posted: Wed Dec 15, 2010 8:55 am
You dont need LK1 unless you are getting removal of rear seats certified at the same time
Vehicle: Daisy
Post Posted: Wed Dec 15, 2010 8:57 am
Cool, well I don't want to do that, That's just what the QT bloke told me on the phone, he didn't ask what type of vehicle or anything so probably just assumed I'd be removing some and not putting them back in.
Post Posted: Wed Dec 15, 2010 11:30 am
Don't go to Ballina! Thats NSW! We have a different system. (unless the guy does qld)
Vehicle: Daisy
Post Posted: Wed Dec 15, 2010 6:09 pm
Good call, I was just using it as a distance reference for how far I was prepared to travel though.
Vehicle: 94 hard top sierra
Post Posted: Fri Sep 05, 2014 10:27 pm
Chopz wrote:
Theres 2 types of autotechnica seats, theres ones that normally go on sale for $220 a pair(the ones pictured above), and theres a slightly better version which are on sale at repco now for $300 a pair.
The first pair (cheaper ones) are shit, the side ass supports at the bottom are way to high, and if you have any sort of lift in a sierra makes getting in and out of them really hard, prepare to crush the meat and 2 veg a few times. The second more expensive pair arnt so high and also have like a pleather insert stiched around the raised areas, so they dont eventually wear away from getting in and out all the time like the cheaper version do.
are these the ones? http://www.autotecnica.com.au/sport-comfort-seat
if not could you let me know which ones
Post Posted: Fri Sep 05, 2014 10:44 pm
Armsup new guy signs up, searched, found thread from 2010. :youdaman: Image
Post Posted: Sun Sep 07, 2014 8:23 pm
And yes cruzinzook, they are the right ones. I ran them in my Sierra for many years as a daily. The side bolsters padding did start to move a little which was uncomfortable but I would recommend them for the price.
Post Posted: Mon Sep 08, 2014 4:48 pm
thanks for that zook fan, looking at putting a set in mine. although the originals are comfy bit of safety is better
Users browsing this forum: Google [Bot] and 180 guests
