It is currently Sun Sep 20, 2026 1:43 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
Post Posted: Thu Dec 23, 2010 7:22 am
bagnkat wrote:
from memory the spline count / shaft diameter was different.
yes indeed the spline count/shaft diameters are different
97 Coily 2" susp lift 2" body lift + more
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Fri Dec 24, 2010 2:06 am
If you got the drive shafts but you cant do half shafts becasue they are different, Do what I did and just take the uni flange in half and do half and half unis, not hard and works well.
Ive now put my orginal case back in with 6.5:1 gears.
I really should sell the 1L case now..
Post Posted: Fri Dec 24, 2010 2:46 am
yeah right that idea crossed my mind but i wasn't sure if the uni's were the same size, i think i'll give it a go.
Cheers Richo
Vehicle: Suzuki Sierra SJ80
Post Posted: Fri Jul 05, 2013 12:12 am
Have a quick question, im half way through putting a WT leafy case in my coily but the mounts dont sit 100% and i read here that i need WT mounts which makes sense but the ones on ebay say they will fit both sj70 and sj80? Im pretty sure this is the same set i put in my sierra a few months ago aswell. Where could i find WT ones would fit?
Cheers,
Trev
Post Posted: Fri Jul 05, 2013 3:15 am
You need to use the mounting arms from a WT case, the rubber mounts are all the same
Post Posted: Fri Jul 05, 2013 9:45 am
Ah I see, thanks for that.
Users browsing this forum: No registered users and 98 guests
