It is currently Fri Oct 16, 2026 5:04 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Post Posted: Tue Feb 08, 2011 6:49 am
alex wrote:
doesn't coilys have 3.9 diff gears and rhino has 3.7???
^^^That would be it :wink:
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Tue Feb 08, 2011 7:28 am
What about 5th gear ratio? i've heard wt and nt are slightly different, so coily may also be different.
Post Posted: Tue Feb 08, 2011 7:34 am
It's a coily...of course it's different :roll:
Post Posted: Tue Feb 08, 2011 7:44 am
Coily should be 0.83, same as WT (well at least later model WT).
The 3.7 vs 3.9 diff should account for all the 200rpm difference between Rhino and Rusho.
Clearance Hole Technology :P
Vehicle: 98 Maruti
Post Posted: Wed Feb 09, 2011 11:59 am
so now i have my heart set on a set of 6.5s
but i am a little worried about busting tranny mounts, what is teh best way to avoid this? any simple mods or just moding the crossmember?
thanks for the advice so far all
Post Posted: Wed Feb 09, 2011 12:19 pm
the mounts cost something like $13 and in the 3 or so years that i have had
6.5s i have broken 2. i reckon they are a nice cheap driveline fuse.
i dont abuse my cars but. well i do a bit but it is nicer to crawl over stuff then to go flat out
Post Posted: Wed Feb 09, 2011 12:24 pm
Thats if you end up getting descent quality mounts (hard to find). My first one on this zuk died within 20k's of me getting it on the road, the metal just fell off the rubber!
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Wed Feb 09, 2011 12:33 pm
i have a stash of old ones that i got off sierra wrecks :wink: :lol: i only guessed at the $13 :oops:
Post Posted: Wed Feb 09, 2011 11:54 pm
That's the only way to do it!! Ive found that the strength of a single old genuine suzi mount is still stronger than a pair of aftermarket ones!
Lil Foot!
Post Posted: Thu Feb 10, 2011 2:13 am
so what would you all reconmend for 29's?
I was looking at the 4.16's because that would put it back to stock gearing, but by the sounds of this thread you all think it would be better below stock gearing on road???
My Rig --> Click WWW
Post Posted: Thu Feb 10, 2011 2:18 am
4.16 work very well with 29's, you will not be disappointed! Although if you can get the 1.3 reving to 3500-3700 in 5th at 100 it will be much happier as well as more efficient. 4.9's will do it or swapping your centers to 3.9's with 4.16's.
Dan
Lil Foot!
Post Posted: Thu Feb 10, 2011 2:26 am
so you think 4.9's will be better? But they are $100 more = (
why do you think reving higher will be better for 5th?
Considering I do most driving on road my aim is to get the car at its best for on road driving
Post Posted: Thu Feb 10, 2011 2:45 am
The 1.3 and also the 1.6 make there peak torque (which relates to peak efficiency) higher in the rev range than the stock 3.3K which is where a stock WT setup revs are at 100KPH in 5th. Drop back to 4th and this climbs to ~4k (cant remember exactly can someone clarify). With the bigger tires these rpm's will get even lower, worse at a true 100, not a speedo 100. So you will find your self dropping between 5th and 4th, maybe even 3rd on the highway all the time with anything remotely reassembling a hill. I drive alot of highway every year, briz to cairns and back and I found that both of these engines tend to be happier at the ~3.5k mark.
I had a hardtop with a carb 1.3 on 235's and 3.9 gears and now have a softy with 30's, 4.9's and 3.7's. These setups worked quite well on road for me.
If you can fork out the extra 100 get the 4.9's or if not get the 4.16's and if your not happy with it track down some NT centers for your diffs.
Dan
Lil Foot!
Users browsing this forum: Google [Bot] and 256 guests
