It is currently Sun Nov 15, 2026 1:16 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
Post Posted: Fri Apr 29, 2011 11:00 pm
lump_a_charcoal wrote:
stockman wrote:
Why not pull it out and carry a 25l jerry can or two.
I'm sure for the majority of your driving you wouldn't need a long range tank.
A LRT is safer than jerry cans in a car.
X287552172454245123764123754.1
Vehicle: 4wd
Post Posted: Fri Apr 29, 2011 11:23 pm
I understand that. But I'd rather carry a jerry then have that so called long range conversion.
Watch out or you'll get sued.
Post Posted: Fri Apr 29, 2011 11:35 pm
The issue isn't the tank though. It's the lines running past that particular spot.
Post Posted: Fri Apr 29, 2011 11:37 pm
True, but he's got both tanks and the hardware why not use it?
Moving all the switching to the back and minimizing the lines as /\ /\ /\ those guys mentioned will work just fine, keep his capacity,and be safe.
Vehicle: 4wd
Post Posted: Fri Apr 29, 2011 11:45 pm
I'd hate to see what the underside looks like.
At the end of the day it should be getting 300-400k's out of a standard tank and unless your in the middle of no where the only benefit of a long range tank it a bit of fill up time and a possible saving when fuel is cheap.
I would pull it all out and run a jerry for the longer trips if you need one.
or
Pull it out, put in a proper long range tank and run the standard lines.
But each to there own.
I can understand running dual tanks under a larger car, but two under a Sierra would be a squeeze.
Post Posted: Fri Apr 29, 2011 11:57 pm
Oh that;s right you guys have long range tanks available. We don't have those here. The most we get is 4 extra gallons from a petroworks tank, but those things hang lower than the stock unit and are bigger=Image
Post Posted: Sat Apr 30, 2011 12:02 am
More room in a lwb for dual tanks, with stockish suspension.
Post Posted: Sat Apr 30, 2011 3:04 am
More room in a trayback sierra. 85L and I could still squeeze in a stocko 42L if I needed it :wink:
Post Posted: Sat Apr 30, 2011 3:46 am
Id love an 85l tank in my maruti, big time.
Users browsing this forum: No registered users and 84 guests
