It is currently Sat Oct 31, 2026 9:43 am
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Tue May 03, 2011 11:04 pm
you are smarter than me, go work out out how many degrees of change you get from teh height change caused by the shackle cycling, the end of the spring would change what 80mm from full compression to full droop?
Post Posted: Tue May 03, 2011 11:11 pm
Vehicle: '92 Sierra
Post Posted: Tue May 03, 2011 11:16 pm
Extended shackles and redrilled spring hangers for RUF throws the castor off. Especially since there seems to be hardly any castor in the stock sierra anyway. I'm back to stock shackles after running extended ones with RUF and I left the castor wedges in. I reckon they are the easiest way to get the sierra to track well. On the freeway especially. Good return to centre and trucks/wind don't cause wandering like they used to. Either way I don't see caster causing death wobbles. I'm sure lack of it would make them a lot more noticeable though.
On topic, another thing to check for the wobbles is flogged out shackle bolts. Allows the shackle to move laterally. Everything else sounds like it's been covered.
Post Posted: Tue May 03, 2011 11:43 pm
4.82 degrees using a 950mm spring and central axle location :lol:
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Tue May 03, 2011 11:48 pm
why would the axle location come into it, the angle change is going to be the same all the way along the spring wont it?
Post Posted: Tue May 03, 2011 11:50 pm
What if the spring is 'S' shaped during flex? :wink:
Post Posted: Tue May 03, 2011 11:51 pm
Correct! Its just the way i drew it up :wink:
Lil Foot!
Post Posted: Tue May 03, 2011 11:52 pm
lol if you can make an S shape at speed on the front end other than crawling your gonna have more issues than castor change
Lil Foot!
Post Posted: Tue May 03, 2011 11:54 pm
Yeah I know this.... :lol:
Post Posted: Tue May 03, 2011 11:55 pm
ok go a bit further, whats the height change from a normal shackle angle on a stock shackle to the worst possible, IE vertical?
Post Posted: Tue May 03, 2011 11:56 pm
my guess would be about 20-30mm.
Post Posted: Wed May 04, 2011 12:00 am
Post Posted: Wed May 04, 2011 12:01 am
If we assume that the angle of stock is say 45degrees then the effective shackle height is 56mm thus the difference in heights here is 24mm.
Therefore angular change at diff = 1.6degrees.
So if stock castor is say 2.5degrees then your only left with 0.9deg
Lil Foot!
Post Posted: Wed May 04, 2011 12:03 am
What is the "normal" shackle length.
Post Posted: Wed May 04, 2011 12:04 am
80mm pin to pin from memory?
stock isnt 45 degrees is it, otherwise rather than carby threads every 3 days we would have a omg my shackle jsut fell over and it jammed under the bumper threads
70mm pin to pin
Post Posted: Wed May 04, 2011 12:05 am
Its about 30 degrees from horizonal. It looks to be about 45 degrees from the chassis, which at the front is on about a 15 degree downward slope.
Well give me a number to work with then :wink:
Lil Foot!
Post Posted: Wed May 04, 2011 12:12 am
Don't forget of course the "ideal" shackle angle is dependant on the arch of the leaf its attached to... if the leaf is dead flat then the shackle angle can only decrease, but if the leaf is really arched then its got no droop and can only compress - so in the case of very lifted leaves a more vertical shackle angle would be more desirable to allow for the spring to compress.
Post Posted: Wed May 04, 2011 12:14 am
Fateveryoneremembercamothefallenzook says 30 from horizontal :)
Yes, and also length has to be considered. I very long leaf will need a longer shackle to allow full movement, and a shorter leaf will not need this.
Post Posted: Wed May 04, 2011 12:15 am
Sorry I meant verticle. :oops: Didn't read what I Typed. And cammo doesn't have leaves :roll:
Post Posted: Wed May 04, 2011 12:18 am
In regard to this, shouldn't you have a flat (sort of) shackle angle, protected from going too far by bump stops, this would allow maximum droop wouldn't it ?
Post Posted: Wed May 04, 2011 12:27 am
i think the problem with shackle droop is its like a drop shackle - its unsprung, so before the spring gets a chance to work the shackle has to drop to the point it picks up the spring tension. Thats my dumb logic on it anyway?
Post Posted: Wed May 04, 2011 12:36 am
Post Posted: Wed May 04, 2011 1:37 am
yeah but we are tlaking about castor change due to lifted springs in turn causing wobbles, not bloody suspension travel
Post Posted: Wed May 04, 2011 1:40 am
crikey, did we get off course, that must be a first.
I don't understand why, its beyond me, but everything I have read says if you lift over 2" you need to address caster or you will get the wobbles.
Post Posted: Wed May 04, 2011 1:43 am
I've never read that :? Many peeps say that extended shackles will alter castor though. I've never heard of castor being the CAUSE of wobbles. Increased lateral movement in the bushes due to longer shackles maybe......
Users browsing this forum: Google [Bot] and 438 guests
