It is currently Thu Oct 08, 2026 12:02 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
Post Posted: Mon May 09, 2011 8:41 pm
Just don't go and get bogged while you're out alone ;)
Post Posted: Mon May 09, 2011 9:04 pm
11_evl wrote:
its funny to think you guys are soo worried about starting your car in low range while your outside...
yes its not ideal but no means bad or dangerous...
maybe is for the cars not setup that have 31s and STD gearing that will do 120 km/h in low range but for most with gearing its not a problem...
first gear, 6.5 transfer, and 2000rpm, how fast is the car going, what 5km/h... hardly something to get all grimbo about to sssiera..
just farken relax hey
I think the concern is somebody that may not have as much common sense skills as others reading its ok to have a stuck car running and driving while you try to push it out by yourself and the resulting removal of limbs that may ensue
Post Posted: Mon May 09, 2011 10:29 pm
My brains been thinking of an EFI type hand throttle,
I really miss it with the Vitara.
Altho its auto, so no probs on hill starts,
I do get my foot bounced off the throttle in bumpy river crossings.
Nearly got swamped with my own bow wave :)
Could be a switch to trip the idle up circuit,
but probably be a mechanical thing on the pedal.
Post Posted: Tue May 10, 2011 2:23 am
thats the problem with the world today, ppl are lacking common sense.
Post Posted: Tue May 10, 2011 2:30 am
You could get up to about 1400rpm triggering the AC compressor on input to the ecu
You could also fit cruise control but put the speed trigger on the Coil rather than speed output so its used to hold revs not speed, will work better in lowrange
I also have a theory that seeing the idle up solenoid is a PWM controlled solenoid (so is opening and closing rapidly with the open time increased to get higher revs) that the Jaycar motor speed controller kit could be stuck into the circuit with a knob on teh dash to control it, this would fix throttle like a hand throttle but not revs.
Post Posted: Tue May 10, 2011 2:49 am
Thats got me thinking.
Next time I have nothing to do,
I will look into it more seriously.
Post Posted: Tue May 10, 2011 5:10 am
SSSIERA wrote:
great if ur doing a 4x4 mish by urself. being able to crank the trottle on in low range when u get bogged then get out and push is great. though this can be done with cruize controll aswell. witch is probs a better/ more available option
WTF, that HAS to be the dumbest thing I've read on here for a while...
The early landys had a throttle lock, and doing the push while engine engaged/ going was a very common thing.
Only in first low, or once unbogged, away she goes.
When I was a kid I saw this a fair bit, and even before my teens I thought what a dumb thing to do, but it was always done on soft sand.
Users browsing this forum: No registered users and 96 guests
