It is currently Sun Nov 15, 2026 10:44 am
Post new topic Reply to topic  [ 155 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Post Posted: Thu Oct 20, 2011 10:24 pm
squibby wrote:
So if I put a MkII transfer into my MkIII, does the reduction only come into play when in low range, or is it always effective?
30% comes into play in both high and low range.
Post Posted: Fri Oct 21, 2011 2:55 am
So what is the best/easiest way to get 15% reduction? That would be pretty ideal for vvt jimny with 235 Tyres?
Better than stock...but not by much.
 Profile YIM
Post Posted: Fri Oct 21, 2011 3:07 am
If you can find 15% lower diff ratios it would be the easiest way. Option B Non VVT gearbox and Sierra transfer. Don't think any of the VVT transfer kits give a 15% reduction.
Post Posted: Fri Oct 21, 2011 9:00 am
great thread thanks
Post Posted: Fri Oct 21, 2011 10:09 am
I wonder what Twisted4x4 are going to do (and when)
 Profile YIM
Post Posted: Mon Nov 21, 2011 8:31 am
monkey wrote:
If yours is a manual VVT it will have a transfer box ratio of 1:1 in high and 2.002:1 in low. The auto VVT uses a different transfer box that is 1.32:1 in high and 2.643:1 in low, so could be an easy swap and still giving you a good reduction.
The manual car has 4.3:1 diffs and I think they are the same for the auto.
I think using a AUTO t-case from a VVT jimny sounds like a easy path for me now :D just trying to figure out what sort of reduction it;s going to offer...
I can now confirm this swap works.... 22% reduction in high and 32% in low(from what Brett form suzuki shop told me)...
Also what reduction would i end up with if i had MKIII gearbox and MKI diffs(4.11?), with a sierra transfer? 35% sound about right?
Post Posted: Mon Nov 21, 2011 8:15 pm
Yep, about that I think.
Post Posted: Tue Nov 22, 2011 8:19 am
mhh....might have to go bigger tyre's then :blink:
:mrgreen:
Post Posted: Tue Nov 22, 2011 10:54 am
:roll:
Post Posted: Mon Nov 28, 2011 6:45 am
Mr nutter,
How much reduction will i end up with if i out a mark II gear box in with the mark III transfer?
And what jack shaft would i need? Mark III jack shaft or mark II? :?
Post Posted: Mon Nov 28, 2011 7:20 pm
monkey wrote:
Mr nutter,
It would go the other way, you need to re-read the beginning of this thread for the answers. The other way around is probably the better choice; Mark II gearbox with Mark II Transfer for a 30% reduction. Only thing you'd need is a lengthened Mark II jack shaft and a transfer lever boot from any earlier Jimny.
Post Posted: Tue Nov 29, 2011 5:11 am
That doesn't sound right. Those ratios are both 32%. If it wass 22/32, I would have already done it.
Post Posted: Tue Nov 29, 2011 5:42 am
Well spotted
Post Posted: Tue Nov 29, 2011 6:36 am
I recall pointing out the same thing in another thread somewhere
Post Posted: Mon Dec 12, 2011 12:17 pm
whats the best way to get gearing back to standard with 30s in a push button t/case in a jimny
looking for a 06 jimny
Post Posted: Sun Jan 08, 2012 5:39 am
Dylan, I am contemplating the same thing when I put on 31's. The closest and simplest option I have come up with is a AT VVT case. being 32%/32%. Your revs will be a bit higher in high but I think its manageable.
Post Posted: Sun Jan 08, 2012 7:04 am
I also want to run 30's with a vvt push button and this seems to much to me. I think the 20% reduction gears would be better..........There must be a better option, all i want is a slight drop in high and crawler gears in low but all options seem to be to expensive. Its freaking ridiculous.
Post Posted: Sun Jan 08, 2012 8:05 pm
If you never want to drive on the highway again at a reasonable speed. 30s would only need a 15% reduction to achieve "back to standard" gearing.
@ Dylan -- When you say 30s are you talking about 30x9.5 or 235/75
bearlives wrote:
I also want to run 30's with a vvt push button and this seems to much to me. I think the 20% reduction gears would be better..........There must be a better option, all i want is a slight drop in high and crawler gears in low but all options seem to be too expensive. Its freaking ridiculous.
30s with my set-up would still have a small reduction in high but theres no way to gear low down while retaining the high. You could go for a WT Sierra transfer with 416 gears and taller diff ratios and Mark II gearbox. Sadly you're up for bucks no matter which way you go. Easiest option would be 31s with 20% reduction main drive in your existing transfer and then the APIO low reduction.
Post Posted: Sat Jan 21, 2012 9:55 am
mark II jimny with mark III diff gears 6% reduction? would be alright with 235/75r15? what your thoughts?
2004 Jimny
2" ome lift
15mm spacers
235 75's
Post Posted: Sat Jan 21, 2012 9:56 am
Not worth it IMO.....
Post Posted: Thu Oct 04, 2012 8:13 pm
x2
215/75R15 yes
Post Posted: Thu Oct 04, 2012 8:54 pm
iv got a calculator iv made for speed and rpm for gearing sets including gearbox (but you need to know the actual ratio) to put in it. does metric and imperial tyres and does high and low transfer (if you know the ratio) if anyone wants it. it doesn't have percent change but it can be added easy enough.
Vehicle: LJ50V, SJ70
Post Posted: Fri Oct 05, 2012 3:15 am
What are the options for taller diff ratios for a Mk1 Jimny (4.09 diffs, right?) Will the SJ80 Coily (3.7 ratio) front diff fit the Jimny?
Vehicle: 03 Jimny
Post Posted: Fri Oct 05, 2012 6:40 am
coilys are 3.9 ratio?
Post Posted: Fri Oct 05, 2012 7:05 am
I don't know whether the front diff of a coily would fit, hopefully someone who actually knows will chime in.
3.9 would be perfect for me with 4.16 gears.
Post Posted: Wed Jul 03, 2013 8:21 am
Are trial jimny gears well made? Or would I be better off sourcing auto transfer gears from suzuki?
Post Posted: Wed Jul 03, 2013 12:01 pm
Haven't heard of anyone breaking them
Post Posted: Wed Jul 03, 2013 7:33 pm
Since this thread has been brought to the top again, I might correct some numbers we now know and have been stated in other threads.
The Auto VVT Jimny is actually 27% lower than the Manual case, in Hi and Lo. It is not 32% as suggested in the sales brochure (At least the Aus models anyway). The chain is also 5mm narrower and a few cm longer. Meaning that it is not as strong as the manual.
I still believe a chain tensioner with an external adjustment would be possible.
Post Posted: Thu Jul 04, 2013 7:14 am
When are you going to sort your gears Bugsta, you've been talking about it for ever. Jimny running at the moment?
Considering you only drive it as a weekend toy you should just throw a Sierra case in behind your current gearbox, you'll have a huge reduction. Just put up with 80km/h highway.
Post Posted: Thu Jul 04, 2013 6:25 pm
Stock box - huge reduction in High yes. Not so much in low.
The plan is for trialjimny gears, but this is pointless with a slipping chain.
I still use it for about town and weekend get aways. Just no low range or towing.
Users browsing this forum: No registered users and 68 guests
