| Author |
Message |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Sun Jun 12, 2011 11:28 am |
I can swap springs in about 20 minutes. As per royce's comments changing spring height isn't going to compensate for load - more load needs more spring rate.
If you genuinely carry 700kg of payload it's time to change car. You're at least 300kg over GV for a sierra.
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sun Jun 12, 2011 11:41 am |
Gwagensteve wrote: I can swap springs in about 20 minutes. As per royce's comments changing spring height isn't going to compensate for load - more load needs more spring rate.
yeah i know, however i like my sierra.
there is 260kg just in fluids for the car. not counting fluids for me.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
dano_mung
Joined: Sun May 17, 2009 11:30 pm Posts: 237 Location: Brisbane
 Posted: Sun Jun 12, 2011 12:03 pm |
Love the shackle angle on the rear...
_________________ I drive my Daihatsu like its a Suzuki!
shep
 Posted: Sun Jun 12, 2011 12:20 pm |
dano_mung wrote: Love the shackle angle on the rear...
all the weight was on the drivers side spring as i broke the chassis on the passenger side.
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Sun Jun 12, 2011 12:23 pm |
Put ya spare on the bonnet. That should help with weight distribution.
And nice long range fuel tank
_________________ 2013 GV 1998 SV420 ute
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sun Jun 12, 2011 11:48 pm |
and the hose in the tank?
i will be double 4-linking my lwb when i get some time, but what steve is saying about radius arms is sounding about right for your dusty overloaded trips...
shep
 Posted: Mon Jun 13, 2011 12:00 am |
31zook wrote: the and the hose in tank?  i will be double 4-linking my lwb when i get some time, but what steve is saying about radius arms is sounding about right for your dusty overloaded trips...
easiest way to get fuel from a jerry can into the tank
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Mon Jun 13, 2011 12:13 am |
I used pajero rear radius arms. Front and rear on the sierra, with a panhard. With all the bolts in it didn't flex, because how can it? you have gripped the diff housing on both sides, it'll only flex as much as the bushes allow. If you remove one end bolt from one side of the diff it flexed really well because you relased it's grip and made floppy links now. It worked like that very well.
I did two rockcrawling comps like that on 32s and got 2nd and 3rd against Mick from Superior Engineerings Floppy Patrol on 37s.
It was not used on road though. The only reason i changed that was because the diff housings copped a flogging on the rocks and i wanted bigger tyres and bigger stronger diffs. I now have A frame front and rear with hilux diffs. stupid flex but the rear is bit wrong with bad pinion angle on extreme flex, but that's ok, it still goes ok for what i do.
shep
 Posted: Mon Jun 13, 2011 12:23 am |
thanks steve. would ya have a pic of how it flexed with all the bolts in?
what about a X link or are they like drop shackles.
steve
Vehicle: 75 Cruiser
 Posted: Mon Jun 13, 2011 12:27 am |
i'll look for some, but it'd be the same as a coily sierra as that's the same system, that's why they tear brackets off the diff housing, the twisting strain.
I have seen the x link, looks ok? basicly removing the end bolts and linking each side together?
shep
 Posted: Mon Jun 13, 2011 3:40 am |
this is what i can get form the dump
gen 2 paj. these are the longest arms i was able to measure
80 series. around 50mm shorter then paj but with a different chassis mount
some sort of SWB patrol/maverick thing. around 200mm shorter then a paj but with the same type of chassis mount
4 link from a grey import pathfinder
grey import surf
there are also arms from 70 series toyota's and GU wagons however i couldn't flip them over with my sierra
steve
Vehicle: 75 Cruiser
 Posted: Mon Jun 13, 2011 3:46 am |
If you grab the hole diff, and cut the diff off each side of the mount and then weld the half circle of the remaining diff around your diff, so it still has the standard mount, might save some work making new mounts.
Gwagensteve
 Posted: Mon Jun 13, 2011 8:25 am |
My pick of those would be the pajero arms, mounted upside down. With the pin at the chassis end, you'll have plenty of travel if you later convert to three link.
PS pathy's were 5 link rear - there's a panhard not evident in the photo. Quite a good design too.
Patrols can't flex their front end with 3 tonnes of pootrol on them - a sierra, even as heavy as yours, won't stand a chance.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Mon Jun 13, 2011 8:30 am |
Coiled pajs flex good too.
_________________ mlm
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Mon Jun 13, 2011 8:33 am |
What about something really simple like the jimny 3-link, just with longer arms?
_________________ Tell my arse, he actually gives a crap!
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Mon Jun 13, 2011 8:42 am |
monkey wrote: What about something really simple like the jimny 3-link, just with longer arms?
Sounds good, but by the time you sit down and take the time to measure it all, work out what how it's going to behave. Find the mounting points etc it's not soo simple.
There was a couple of really good threads on pirate4x4 shep but for some reason I cant find them. One had a simple write up of each setup, and how it generally behaved.
Wil search some more tomorrow.
monley
 Posted: Mon Jun 13, 2011 8:47 am |
shakes wrote: monkey wrote: What about something really simple like the jimny 3-link, just with longer arms? Sounds good, but by the time you sit down and take the time to measure it all, work out what how it's going to behave. Find the mounting points etc it's not soo simple. There was a couple of really good threads on pirate4x4 shep but for some reason I cant find them. One had a simple write up of each setup, and how it generally behaved. Wil search some more tomorrow.
But easier than doing a 4-link setup from my under standing
royce
I cant believe either of you havent figured the whole tone of this thread was to do jsut that and Steve even chimed in with why he didnt like it too much and Shep even put up pics of potential arms
Gwagensteve
 Posted: Mon Jun 13, 2011 9:00 am |
Er, that's exactly what a range rover front or pajero rear is - have a good look at the photos Shep has posted - they're all exactly the same in configuration as a Jimny.
None of the jmny parts are worth a pinch of poo. The panhards break, the shocks are too short, and the arms bend.
monley
 Posted: Mon Jun 13, 2011 9:09 am |
Gwagensteve wrote: monkey wrote: What about something really simple like the jimny 3-link, just with longer arms? Er, that's exactly what a range rover front or pajero rear is - have a good look at the photos Shep has posted - they're all exactly the same in configuration as a Jimny. None of the jmny parts are worth a pinch of poo. The panhards break, the shocks are too short, and the arms bend.
I'm a bit slow today
I agree that the stock panhards are shit, that why i have the TD ones, and the arms are piss weak, i think i have twisted and bent one of mine yesterday. And shock been to short are you referring to stock shocks or after market?
Gwagensteve
 Posted: Mon Jun 13, 2011 9:17 am |
Does it matter?
A jimny is designed for 6"/5" of travel. Aftermarket shocks for a jimny might add a couple of inches to that, but why lock yourself into a jimny part# (stock of aftermarket) when you are making all the mounts from scratch?
I'm generally a big fan of OME N76 shocks, but with the "new" radius arm setup were working on now, it looks like Bilstein 5100 shocks might be a better choice. (6, 8, 10, 12 14" travel)
Gwagensteve
 Posted: Thu Jun 16, 2011 9:47 am |
shep
 Posted: Wed Jul 06, 2011 5:26 am |
i am going to look a bit closer at a paj rear end as this is more then enough flex for me.
dunno about the front as yet.
Gwagensteve
 Posted: Wed Jul 06, 2011 5:35 am |
hehehe - don't get excited - that's a trick photo. I have one radius arm bolt pulled because we were measuring clearances for when it goes three link, (when it will have that much travel) and shock clearances for Michael's trolley tug. In this photo the rearmost driver's side bolt has been pulled on the axle.
You can experiment, but generally, handling will go to poo if you drive the car with one bolt pulled. It used to be common for Rangie owners to pull one front bolt to free the front up off road. Makes them pretty wobbly on road though.
This is how much travel my car has with all the bolts in. It was unladen in this photo though.
and on the same day in the same spot with one bolt pulled:
Note how the front end has unloaded once the bolt has been pulled. It's not a good solution for balanced behaviour with a leaf front end ebcause of the huge difference in roll stiffness front to rear it creates. That's why I'm not going to three link the rear of mine until I coil the front.
shep
 Posted: Wed Jan 25, 2012 7:37 pm |
i am back to looking at this. i have settled on paj rear arms for the rear of the sierra.
now what about the front? would be best if i can use factory parts.
Gwagensteve
 Posted: Wed Jan 25, 2012 7:45 pm |
Check my build thread - it's exactly what I am working on now, and it's even more relevant as I'm converting to AW-4 at the same time.
Should have the gearbox crossmember complete today, which is the critical bit.
shep
 Posted: Wed Jan 25, 2012 7:57 pm |
cool. i am using a crossmember from a kit. i need to use either kits or factory parts
as then i can hopefully avoid needing a engineer to sign off on the mods.
Gwagensteve
 Posted: Wed Jan 25, 2012 8:03 pm |
shep wrote: cool. i am using a crossmember from a kit. i need to use either kits or factory parts as then i can hopefully avoid needing a engineer to sign off on the mods.
I don't believe it's achievable under those circumstances. Sooner or later you will have to weld something to the chassis so an engineer will need to be involved if you need it legal. I'd get the engineer involved now and know you can drive down the road without sweating you are going to get pulled over.
Even something like the trail slayer kit requires chassis and axle welding=engineering required, and just because it's a kit doesn't mean an engineer will accept it. There are good kits and bad kits.
I'm using stock links, stock coil towers, and a stock pan hard, but hanging it all together will require custom chassis work - it's unavoidable.
shep
 Posted: Wed Jan 25, 2012 9:25 pm |
There is nO engineer to get involved. We do a submission to a commitee made up of car enthusiasts and they decide what the next steP is. If they like it then ya get the go ahead.
Welding on the chassIs is unavoidable however if I can use factory suspension bits then it will look a lot better on paper.
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Wed Jan 25, 2012 9:27 pm |
