It is currently Sat Sep 19, 2026 10:51 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2
Vehicle: Jeep
Post Posted: Wed Jul 13, 2011 5:31 pm
WTF are you on about, has AZ become politically correct over night, so you're telling me i can't call it a pissing contest or my wang is bigger than yours? :roll:
i'm just stating fact, pretty sure B4T's GV is the tallest i've seen on AZ with out a body lift & i give him credit for it. but i think Mugwui's will be taller as he's running a 2" bodylift, 2" spring lift, 35mm spacers & 31's, do the maths... i'd say he's just pissed on the competition.
:rofl: :rofl: :rofl: AZ is far from being PC ! ( Which i like ) :rofl: :rofl: :rofl:
Now you are stating fact... settle... :rofl:
Post Posted: Thu Jul 14, 2011 6:39 am
Ben_Sierra wrote:
Haha look at all you GV drivers "My lift's bigger than your lift" "No its not, you measured it wrong" :P
B4T only started this pissing contest cause his GV wang is bigger than the rest. :lol: :lol: :lol:
I see Mugwui hasn't posted yet, would be interesting to see how tall his GV is.
I havent finished with mine yet.
Still have to fit bigger tyres, fit rear locker, put extensions on the struts, fit taller rear coils and longer rear shocks.
Overall height lets you compare different suspension and tyre combos.
Fitting Larger tyres will also give you lift and thats what i wanted to know. If i was only after suspension I would have asked "how much suspension lift do you have"
But any way some did what i asked and i got some answers i was after.
So you can now continue with the hijack and confusion of yet another topic.
Post Posted: Thu Jul 14, 2011 10:47 am
I can jump in on this on satdee, the one i'm getting looks to have a lift in it.
Red springs that i'm thinking is pedders, and iron man shocks.
Post Posted: Sun Jul 31, 2011 6:15 am
793mm to the wheel arch
215mm to cross member.
Thats with ironman 2" lift kit and 225/75/16 BFG a/t tyres.
I did loose some hieght though after i added the bar, winch, and second battery - all up about 110kg
Im thinking of adding spring spacers to get it back up again
My Grand Vitara
Vehicle: Jeep
Post Posted: Sun Jul 31, 2011 8:31 am
Ironman dont make a 2in lift kit for the 99 to 05 GV, as far as i know, only 35mm... :wink: :D
Post Posted: Sun Jul 31, 2011 8:34 am
Any respect I had for you just went out the window. .....
Post Posted: Sun Jul 31, 2011 9:05 am
Thats just an idea im toying with as there are not many options with GV's if your struts are too short.
I already have the longer dobinson struts but they are limiting down travel.
If you know of another option i'd like to hear it.
Post Posted: Sun Jul 31, 2011 9:14 am
Ok 35mm then :roll: :lol:
My Grand Vitara
Post Posted: Sun Jul 31, 2011 9:17 am
Whats wrong with strut extentions? :oops:
Can you flip the top strut mounts? Has that been done on a GV before?
My Grand Vitara
Post Posted: Sun Jul 31, 2011 10:48 am
Not sure that would work as the GV have a strut bracethat bolts to the strut top not the strut top mounting holes. that sorta makes sense.
Post Posted: Sun Jul 31, 2011 10:57 am
So do SV's. I have a pair of GV strut tops here, so I'll have a play with a strut top flip scenario and see how it pans out.
Post Posted: Sun Jul 31, 2011 11:26 am
I just measured mine, Front 785mm Rear 805mm with stocko 235/60R16 tyres.
Springs are aftermarket red ones, i'm assuming pedders as they love red.
Vehicle: 2004 SQ625 GV
Post Posted: Sun Jul 31, 2011 1:18 pm
I saw some plate strut extensions on the net the other day. They supplied a spacer so you could refit the strut brace. I saved the shortcut on my work pc so I will post it up tomorrow. Would prefer those than the screw on strut extensions. But we are limited in options.
Post Posted: Sun Jul 31, 2011 1:46 pm
Coo. I haven't seen any other options either. That doesn't make strut extensions a good idea though :P
Post Posted: Mon Aug 01, 2011 12:59 am
As promised. It's SR customs and they use an aluminium spacer foor the strut brace. let me know when you have finished making them Fatzook :wink:
http://www.srcustoms.ca/index.php?page= ... &Itemid=56
Post Posted: Wed Sep 14, 2011 5:06 am
Ok just fitted new springs and spacers.
Dobinson springs
Front with 15mm spacer is now 825mm
Rear with 30mm spacer is now 850
Post Posted: Wed Sep 14, 2011 6:34 am
Post Posted: Wed Sep 14, 2011 6:52 am
stock GV3 with ARB winch bar and a boot full of crap.
830mm ground to middle of the wheel arch
205mm ground to cross member.
Post Posted: Wed Sep 14, 2011 4:29 pm
Post Posted: Thu Sep 15, 2011 6:04 am
Post Posted: Mon Oct 17, 2011 5:46 am
Just an update on my GV.
Ive fitted the 245/75R16 Maxxis Bighorns and with the 40mm coils and the 30mm spacer lift i measure from the ground to under side of wheel arch.
front = 860mm
Rear = 865mm
On compression the rear tyre hits the back of the wheel arch where the outer mud flap moulding is attached but only inside the wheel arch.
The front only hits the chasis rail when on full lock.
Gonna wheell it on cup weekend as it is and see how bad it rubbs and then worry about cutting stuff after.
Vehicle: Jeep
Post Posted: Mon Oct 17, 2011 5:48 am
front = 860mm
Rear = 865mm
Pics !!! :lol:
Post Posted: Mon Oct 17, 2011 7:23 am
front = 860mm
Rear = 865mm
Pics !!! :lol:
give it time....might take some tomorrow.....
Users browsing this forum: Google [Bot] and 132 guests
