Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
Posted: Wed Nov 02, 2011 11:40 am
I thought about it before I found my baleno conversion. Was gonna rebuild the g13 with high comp pistons and a cam, run a weber in a blow through config and run a pipe manifold into a starlet turbo. Use a copper head gasket and run about 7 psi through the stock waste gate. Would require a small efi pump which is easy enough.
Users browsing this forum: Google [Bot] and 156 guests
