It is currently Fri Oct 16, 2026 10:45 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2
Post Posted: Tue Nov 15, 2011 6:38 am
that's an exit, you need a diff as Mr 4x4 said...
Post Posted: Tue Nov 15, 2011 6:47 am
Any one guess what the probability of the ring and pinion being reusable
Post Posted: Tue Nov 15, 2011 6:48 am
3 :helloo:
Post Posted: Tue Nov 15, 2011 7:05 am
seven
Post Posted: Tue Nov 15, 2011 7:16 am
Yep thats not looking too good.
I sprayed everything with the crc co contact cleaner, and replaced my o2 sensor and all my idling issues went away.
Post Posted: Tue Nov 15, 2011 7:17 am
:helloo: you still got that steel diff lying around?
Post Posted: Tue Nov 15, 2011 7:24 am
Yep :lol:
Post Posted: Tue Nov 15, 2011 8:10 am
That diff housing looks just like mine, and just as atari said, you will have some teeth missing off either your Pinion or crown wheel and they have come into contact with the alloy housing inbetween spinning gears... its a bitch of a problem, if you have a 22 Spline Front diff, and yours is a manual, i'd be happy to sell you the one out of my wrecking vitara for 100bucks + post. if thats going to help your cause...
Stocker
Post Posted: Tue Nov 15, 2011 9:08 am
I did replace my CV on the weekend before I took it out. By any weird reason. Could I have put it in wrong or put in a 26 spline by accident.
Just spit balling.
I will investigate a steel diff.
So will the earlier GV diff bolt straight in? I know r&p have to be changed into the steel diff center. But the housing it self bolt straight in?
Post Posted: Tue Nov 15, 2011 9:12 am
yess!! the GV bolts straight in
you can't put a 26 spline CV into a 22 spline diff but you can put a 22 spline CV into a 26 spline diff & get no drive.
but looking at the pic of the cracked housing, i'll bet tomorrows lunch money on it being a fucked diff centre.
Post Posted: Tue Nov 15, 2011 5:53 pm
Like the CV clunks if I try and turn it with the hubs locked. So I assume its working ad it should
Post Posted: Tue Nov 15, 2011 6:14 pm
By the sounds of it she's stuffed mate. Buy a steel front diff from one of the guys and go that route.
Post Posted: Wed Nov 16, 2011 4:59 am
So what locker will I need for a steel diff. I know my 5.1.2 gears go into it. So will an rd88 work(Chinasoong)
Post Posted: Thu Nov 17, 2011 4:08 am
Wanting to order it today so anyone with information about the locker would be greatly appreciated
Thanks to everyone with their help!
Post Posted: Thu Nov 17, 2011 4:24 am
not trying to be a cunt, but have you tried punching "Vitara RD88" into the search function? :?
Post Posted: Thu Nov 17, 2011 4:37 am
Had a quick look. But I didn't use those exact keywords. Your not being a prick, I should of searched harder.
However I still don't fully understand what I need
If I get the steel GV centre and put my r&p in. Will the locker for the vitara fit?
I am not aware how air lockers function or how diff centres work.
Post Posted: Thu Nov 17, 2011 5:03 am
RD88 is the one you want, but there are some mods required.
i'm on my phone, search for a thread started by "Stuey" Vitara RD88 problems.
Post Posted: Thu Nov 17, 2011 5:22 am
That thread doesn't exactly explain too much to me.
He had the j20 engine whilst mine is a g16b. Was the fix to shave down the side gears.
Would they have fixed that issue by now?
Post Posted: Thu Nov 17, 2011 5:30 am
i guess you'll find out when you buy the chinese copylocker. :wink:
Post Posted: Thu Nov 17, 2011 5:47 am
Yes we will. I'll report in when its all installed
Cheers for your help
Post Posted: Thu Nov 17, 2011 6:01 am
i'm not sure if the circlip problem is just related to the SV420 & RD88 + GV steel, but shaving the side gears fixed stuey's problem, i ended up fixing it using the RHS stub axle conversion.
Post Posted: Sat Nov 19, 2011 12:10 am
Look what fell into my lap today
I thought these were air activated? Can't find the airline?
Post Posted: Sat Nov 19, 2011 12:12 am
Found the airline thing lol
Post Posted: Sat Nov 19, 2011 1:02 am
how much?
Post Posted: Sat Nov 19, 2011 2:35 am
$300. Hope that was good. Only one around here
Users browsing this forum: Google [Bot] and 223 guests
