Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
Posted: Thu Jan 12, 2012 9:36 pm
IN2DEP. I'd suggest dealing with one issue at a time. Find the cause of your current drain before you look at alternator. You need to spend some time investigating.
_________________ If you can read this, please tip me back over
Joined: Sat May 19, 2007 11:30 pm Posts: 2535 Location: Perth
Vehicle: 93 Sierra
Posted: Fri Jan 13, 2012 3:01 am
Just by-the-by it could be your brand new alternator that is the cause, if the battery drain problem has started since it was installed. If one of the diodes in the alternator blows then it'll draw current through the alternator coils even when the car is turned off and parked.
The current draw of an alternator with a blown diode is generally enough that you can generate a spark by having the positive connected and then just touching the negative lead to the battery terminal with everything else switched off. Checking with a multimeter is still the best way though.
Users browsing this forum: Google [Bot] and 492 guests
