It is currently Wed Sep 23, 2026 9:00 am
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2
Vehicle: Suzuki Jimny 2010
Post Posted: Wed May 23, 2012 7:34 am
jimny_timmy wrote:
I'm getting a new one tomoz if you'd like me to measure it? Just let me know what I need to measure...
Cool.
Can you measure the thickness of the new rotor, and the hight of the rotor hat from the back of the rotor to the wheel mounting surface.
Cheers 8)
Hey mate, I've got the photos and measurements but I can't get them to upload in here from my phone... Can you give me your email addy and I'll send them to you :)
Vehicle: 03 Jimny
Post Posted: Wed May 23, 2012 7:52 am
jimny_timmy wrote:
Cool.
Cheers 8)
If you have a ifail or android just download photobucket app
Post Posted: Wed May 23, 2012 8:14 am
Yeah I've got all that but the Ifail being ifail, won't upload them to photo bucket :(
Post Posted: Wed May 23, 2012 9:11 am
sales@twinstickoffroad.com
:wink:
Post Posted: Thu May 24, 2012 10:53 am
I am liking the idea of fitting Vit calipers and vented rotors XD
Post Posted: Thu May 24, 2012 7:39 pm
I have LWB Vit rotors and calipers, I'll see if they fit tomorrow.
Post Posted: Thu May 24, 2012 8:51 pm
That would be awesome considering i just wrecked my brakes................
Post Posted: Thu May 24, 2012 9:11 pm
Without hijacking this thread too much, I'd there a trick to getting new rotors in? Mine don't seem to want to go all the way back and the brake pads are stopping the wheel from completely turning around?
Post Posted: Thu May 24, 2012 9:17 pm
Are they the right ones?
vvT AND NON-vvt HAVE DIFFERENT ROTORS.
Sorry bout the CAPS. :roll:
Post Posted: Thu May 24, 2012 9:23 pm
How different do you know? Just the centre hole? Everything else looked the same... I'll be checking the measurements on the centre tomorrow, but I've 95% got it on so I was thinking I was doing something wrong...
Post Posted: Thu May 24, 2012 9:30 pm
Just the centre hole. 1mm I believe. But thats all it would take.
Post Posted: Thu May 24, 2012 9:43 pm
Hmmmm so maybe get it machined? Or whack it in the oven lol
Post Posted: Thu May 24, 2012 9:50 pm
Or take them back and get the right ones?
Post Posted: Thu May 24, 2012 10:20 pm
Yeah I'll see what I can come up with... Thanks mate
Post Posted: Fri May 25, 2012 7:12 am
bigger hammer...
Post Posted: Fri May 25, 2012 2:35 pm
Yep, LWB Vit rotors and calipers fit. Not a massive difference in performance, but I also had brand new pads in my jim, and the pads and rotors I'm using now are second hand, so maybe a bigger difference once I buy new pads and rotors. Also I didn't need to trim the backing plate at all which means there less work then fitting to a sierra.
In my opinion, unless new pads and rotors make a massive difference, this isn't a worth it mod as bleeding the brakes now becomes a big job. The current difference, is instead if having your foot pressed against the pedal to bring it to a stop, you just rest your foot and it pulls up itself. So it works better but the bleeding trade off doesn't make it worth it for me.
Post Posted: Fri May 25, 2012 4:45 pm
F!@k YEAH!!!, I recon with a decent pair of pads and slotted rotors she will pull up well, and maybe less warping with the ventilation XD
Thank you so much 31zook for doing that for us :)
What Vitara exactly did those calipers come off?
Post Posted: Fri May 25, 2012 5:24 pm
Slotted rotors don't increase braking performance. They reduce fade. And to be honest, with the type of money people spend on their slotted rotors ( RDA, DBA etc) all you are buying is a gymick. You need to spend a fair bit more than $200 per rotor to get a performance gain.
Just having the vented rotors and larger caliper ( piston) and maybe a slightly larger contact area will make a difference.
31zook, I'd say yours need a machine and new pads.
Post Posted: Fri May 25, 2012 5:31 pm
The slotted part i mostly like due to the cleaning it does to the surface, will be good for when i go through some mud..........
Post Posted: Fri May 25, 2012 7:50 pm
Yeah, I only bolted em up today to see if they fitted then when they did I figured I may as well see if they feel any better...
They have a sight wobble in them so I'll just get new disks.
Vehicle: 2009 Jimny, Stock with Ram Air
Post Posted: Sun Aug 26, 2012 1:28 pm
Hi Zook
Is yours a VVT Jimny?
I have been trying to find an upgrade for my '09 and this might just tick the box.
I bent my brake pedal earlier this year finding the limits of the front brakes, couldn't get the abs to kick in above 100!
Uploaded with ImageShack.us
Stephen
Vehicle: On the lookout
Post Posted: Mon Aug 27, 2012 1:54 pm
I don't understand
What's changed 31zook to make it a difficult? I can't tell from the picture, not very familiar with my Jimny Callipers really.
Post Posted: Mon Aug 27, 2012 11:07 pm
Skyhigh wrote:
Hi Zook
Stephen
Mate I'm pretty sure this mod is only for non vvt models as vvt's have a bigger hole in the roater over the locking hubs.
Don't quote me on this I just saw it on another post from another member
Post Posted: Tue Aug 28, 2012 5:24 am
squibby wrote:
I don't understand
The nipples don't line up now, so to bleed, I need to take off the caliper and disk, and hold in the correct spot to bleed... Not like stock where the car can stay assembled and just crack a nut.
Users browsing this forum: Google [Bot] and 179 guests
