| Author |
Message |
Mike
lesspostingmorewheeling
Joined: Tue May 06, 2008 11:30 pm Posts: 2236 Location: Under Down Under
 Posted: Sun Jan 11, 2009 6:05 pm |
i suppose the "proper" thing to do would be use a fusable link but i didn't and i've seen other people that haven't either
_________________ [quote="Fluffy"] yeah right mate like Im gunna mov
jamienoble
Joined: Mon Jul 28, 2008 11:30 pm Posts: 128 Location: perth
 Posted: Sun Jan 11, 2009 6:08 pm |
cheers fellas. im off on my merry way to try and save the day!
il let you know how i go!
jamienoble
 Posted: Sun Jan 11, 2009 9:55 pm |
went to supa shit repco and malz and none of them had anything that would work? there was one that would need to be spaced out but then there would be stuff all thread on for the nut?? anyone had tis problem?
Mike
 Posted: Sun Jan 11, 2009 9:59 pm |
yep that was my problem you need to get a pulley that has a groove machined in it to fit the nut properly
jamienoble
 Posted: Sun Jan 11, 2009 10:04 pm |
oh really? can anyone tell me what car has this pulley on it???? it seems to be far harder to do this mod than originally expected
bogfrog
Joined: Mon Dec 29, 2008 10:30 pm Posts: 596 Location: Mt Evelyn Vic
 Posted: Mon Jan 12, 2009 9:00 pm |
jamienoble wrote: oh really? can anyone tell me what car has this pulley on it???? it seems to be far harder to do this mod than originally expected
as said previous just change water pump and crank pulleys to multi groove and leave the EF-L pulley on the alternator (just run on the back few ribs as I have below) and buy a new belt to suit way easier and pulleys can be sort from any wreckers that has suzuki's or barina's etc...Note: You will need a Swift/Barina Water pump as well because the bolt spacings are different and run a thermo fan too but still easy as! Cheers Robb.
jamienoble
 Posted: Tue Jan 13, 2009 2:01 am |
cheers for the pic bog frog. i had considered this method but managed to find a v pulley.. i have put it on the alternator but i am still waiting for a new charge wire and a few other odds and sods. i will trya nd get a photo to put up and get people opinions as to weather it will work or not?? cheers
royce
 Posted: Sat Jan 17, 2009 3:07 am |
anybody want to comment on which signal wire goes where on the back?
jamienoble
 Posted: Sat Jan 17, 2009 4:17 am |
i have just finished wiring it all up! i ended up putting the black wire with white trace on the pin of the alternator closest to the charge wire?? (vaguely remember somthing about it on outers ages ago could be wrong?)
pitty i cant test it cos the fricken thing wont start!
the new problem i have created is when trying to crank it over it makes a flat battery noise?? (tick tick tick tick tick tick really fast) but it is a brand new battery, like im talkign fresh out of the packaging optima yellow top??? and when i turn my headlights on my left one may aswell be turned off its so dim?? anyone help?? urgent! im pretty sure everything is in the right spot??
Mike
 Posted: Sat Jan 17, 2009 4:23 am |
that sounds like a flat battery to me not sure about optima batteries but i've heard that some batteries don't come fully charged when they are new so you might need to charge your battery then try it again
jamienoble
 Posted: Sat Jan 17, 2009 4:28 am |
seriously?? why would one high beam work fine and not the other?? and then i have two hella twin beam work lights on the rear, which both work? i have two hella rock lights which both work? i was thinking maybe an earth but i wouldnt have a clue where to start? for a battery that cost that much i will be pissed if it needs to be charged??
royce
 Posted: Sat Jan 17, 2009 11:20 am |
dont think anyone thats owned an optima is happy enough to get another
check all your fuses, though i doubt thats the cranking prob
jamienoble
 Posted: Sun Jan 18, 2009 7:30 pm |
i am lost for ideas?? i still seem to think it is an earth. i put the multi metre on the pbattery and got 12.58V i assume that is a good reading?? any other suggestions??
Mike
 Posted: Sun Jan 18, 2009 7:31 pm |
that seams about right so does the motor turn over at all?
jamienoble
 Posted: Sun Jan 18, 2009 10:46 pm |
nah nothing at all it just makes a wierd clicking noise which sounds like its coming from the actual ignition and my interior light dims in conjuction with this clicking noise?? any suggestions??
Mike
 Posted: Mon Jan 19, 2009 5:03 am |
mines made two different clicking noises since i had it one was a dodgy starter the other was a flat battery
yours does sound like a flat battery though
do you have another battery you could try?
and when you try to start it make sure all the lights radio etc are off
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Mon Jan 19, 2009 10:13 am |
battery is flat. charge it. Just cause it is new doesn't make it fully charged. Could have been in a warehouse for the last four years
_________________ Camels have nice toes
jamienoble
 Posted: Mon Jan 19, 2009 10:30 pm |
it sounds like a flat battery but the ticking is not coming from the starter motor rather the barrel and the battery has 12.60 volts?? all the fuses are sweet??
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue Jan 20, 2009 1:29 am |
Just a thought but you replaced the main cable from alt with a new one directly to battery didn't you?
Try reconnecting the original to alt and see what happens.
You may have a faulty wire or connection somewhere.
Jas.
jamienoble
 Posted: Tue Jan 20, 2009 1:54 am |
ok i will give that a crack.. now that you say that i put a test light on the alt end once disconected and it was positive?? is this for any reason? it had a disconect on the alt end and when i did a continuity test to a same coloured cable at the battery i got a reading.. and this has a disconnet aswell and was possitive?? does this sound right?? both ends are currently disconeted??
Mike
 Posted: Tue Jan 20, 2009 1:58 am |
if your using a different charge wire disconnect the old charge wire from the alternator and and about 20cms along the wire there is a connector disconnet the it there and leave the orginal chare wire connected to the battery does this make sense?
jamienoble
 Posted: Tue Jan 20, 2009 4:27 am |
yes thankyou!!! tried this and all is sweet!! much appreciated!! long daunting task! can you explain what is happening by doing this!! thanks again mike very helpful!!
Mike
 Posted: Tue Jan 20, 2009 4:33 am |
the orignial charge wire is connected to the loom so it probably powers other "stuff"
if you didn't understand what i said i went and took some photos to try to help me explain but you don't need them now
jamienoble
 Posted: Wed Jan 21, 2009 1:50 am |
i still plan in getting some photos to show the final product! and now that i have done the whole falcon alternator thing i can answer any questions about doing it as it is fresh in my mind!!
jamienoble
 Posted: Wed Jan 21, 2009 2:17 am |
here are a few photos of the finished product.. all seems to work so far so only time will tell.. if you have any question i may be able to help you with them..
jamienoble
 Posted: Wed Jan 21, 2009 2:22 am |
sorry the pics got shrunk when i was resizing them and you cant see all the photo my mistake!! but you get the idea
if you want any specific photos just ask
Mike
 Posted: Wed Jan 21, 2009 4:09 am |
wow your alternator looks newer than mine
what pulley did you end up using?
jamienoble
 Posted: Thu Jan 22, 2009 2:21 am |
haha yeah i bought it off this seedy pedo looking bloke out of the quokka for 80 bucks. it was pretty much brand new.. he still had the box for it.. smooth as anything till some stupid f*$king apprentice rattled the new pulley on to tight and shat it completely.. cbf rebuilding it.. i ended up grinding the neck off the alternator housing.
sorry but the model of pulley i used is the only thing i am still unsure about.. one of my mates is an auto sparky and had a whole box of random pulleys which i mix and matched it to work.. no spacer or anything.. but seems to line up fine and doesn't make any rude noises so far :p
Mike
 Posted: Thu Jan 22, 2009 4:45 am |
jamienoble wrote: i bought it off this seedy pedo looking bloke
that a pretty good bargain they are $750 new mine looks like its been sitting in a paddock for like 27years but it seems to work alright
jamienoble
 Posted: Fri Jan 23, 2009 6:28 am |
yeah i am happy with it! as soon as i start it it seems to boost up to 15 volts straight away.. is this normal?? how long could you run a fridge for with the car off on an optima yellow top battery?? with this alternator setup??
