It is currently Wed Oct 14, 2026 1:45 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2
Vehicle: 2012 jimny
Post Posted: Tue May 07, 2013 6:52 pm
droverdave wrote:
Dan85 wrote:
I know a few guys that use diesel oil in big bore and turbo busas with good results. I use LPG oil in mine and it seems to work well.
Exactly what are these "results" ? and how do you even know it works well?
I struggle with the concept of putting any thing other than the oil that is recomended in the service manual. Both type and viscoscity.
Change it every 5000 or so and forget about it.
I suppose good results was a bad way to put it. I feel that my bike engine works well on oils other than the specific bike oils. The diesel and lpg oils seem to hold up better to the abuse that the modified motors tend to dish out. Also when it comes time to change oil which i do on my bike every 3000km i was finding that even the higher priced "quality" motorcycle oils would feel very thin compared to when its fresh where as the LPG oil i now use comes out in what seems decent condition. I could really hear alot of valve train noise towards the end of that 3000km cycle with motorbike oil but with the LPG oil it all stays fairly civilised. As far as wet clutches go aslong as the oil does not contain friction modifiers the wet clutches will work just fine. Ive been running the LPG oil in my bigbore busa now for about 6 months and guys i know with big turbo setups have been using diesel oil for a fair while longer with no issues. A mate in townsville ran lpg oil in his bigbore busa for years and it always ran great until some crazy lady ran into it.
I cant give you any numerical data that says ones better than the other but i can tell you what the different oils feel like when they are fresh compared to when they are getting dropped out and the motorcyle specific oils felt thin as i said. This is all a bit subjective and off topic i guess but was just trying to say that i know a few people including myself that use the diesel and lpg oils in applications other than diesel and LPG engines without negative side affects. I wont be changing back from LPG oil in my bike. in my jimny with its huge high reving power i doubt its going to care what oil is in it as long as its slippery.
Post Posted: Tue May 07, 2013 7:35 pm
Nobody in this thread so far in reality has any idea of what they are on about cause nobody has tested any oils to see whats actually happened afterwards and I am sure nobody is any form of oil engineer so words like stays golden and goes black and thins out is all just fluff in order to post :)
I would reckon not many people would even know what different viscosity numbers mean (tip, its not thickness) nor realise that /suzuki recycle the viscosity/temp chart in the books, so far my Vitara, bike and swift all had the same thing :)
Vehicle: 2004 Jimny 1.6
Post Posted: Tue May 07, 2013 7:38 pm
I personally don't believe in engine flushes, I have seen it do more harm than good. That's just me though
Post Posted: Tue May 07, 2013 7:59 pm
Yep... As per my original post.
Im starting to lead towards running a deisel oil and making the most of the detergents and cleaning properties they contain.
Vehicle: 1985 lwb sierra UTE
Post Posted: Tue May 07, 2013 8:35 pm
If it is cheap and 15/50 ill run it if goes bang its efi it is for christmas lol .
Seriously I have no idea I owned an old swift with stuffed piston rings it would use 4l a fortnight I used deisel oil in it .. Only cos I was broke and it was the thickest crap I could find ,it lasted 3.5 weeks then I added a an additive and it lated a month .
I don't know how the motor lasted 2 years I think I'm blessed.
Post Posted: Tue May 07, 2013 10:24 pm
for the dollars you spent on oil you could have dropped a second hand engine in. Couldn't have been worse
Post Posted: Wed May 08, 2013 5:43 am
Wasn't that wise back then or really had the time I eventually did but
Vehicle: 92 Suzuki Sierra
Post Posted: Wed May 08, 2013 3:30 pm
my suzuki four stroke generator manuals also have that chart Armsup
anywho i went out and bought 10l of gulf western 15w40 disel oil since these days i can't afford to run 10w60 synthetic
On special at SCA for $45 , picked it over the valvoline which was the same price as it had a SJ/Ci-4 rating, where as the val had SL/CH-4.
In any event i will be mixting it 3 parts to 1 with a 4l 25w60 SG gulf western that i got on special for $12 or something.
hope dem detergents work :P
Post Posted: Wed May 08, 2013 6:30 pm
Did an oil change today. Went with Penrite HPR5 5W40. Got engine warmed up prior to dropping oil and let it drain for 30mins.
Replaced Filter and filled with new oil. Imediately it sounded quieter. A slight rattle after 10mins when revs picked up but nowhere as bad as before.
Did a lifter bleed (2000rpm for 20mins as per suzuki Bulliten) and its 100 times beter than before.
Only Time will tell if its fixed it..
Post Posted: Thu May 09, 2013 8:15 am
This is a good article from a performance engine building site:
The Story of Why Engine Oil Becomes Engine Sludge
In engines that have failed prematurely, the oil has very often been transformed into a high viscosity deposit of brown or black goo, commonly referred to as "sludge."
Fresh engine oil is a clear, free-flowing liquid blend of base stock and additives that contains no fuel, water, coolant, dirt, or other contaminants.
When regular engine oil changes are neglected, normally free-flowing lubricating oil breaks down, becomes contaminated, ceases to flow, and is transformed into a thick soup of waste products. That’s when serious engine damage is imminent.
Why does engine oil break down, combine with contaminants, and form sludge deposits? Chemistry teaches that engine oil is unstable and decomposes in the presence of oxygen at high temperature. The process, called oxidation, occurs naturally after exposure to normal operating conditions for extended periods of time and is accelerated by exposure to severe operating conditions or to excessively high temperatures. Alternatively, accelerated oxidation may be triggered by a combination of any or all of these factors.
During oxidation, the chemical bonds that define the oil molecules are broken, and some of the reaction products accumulate and interact to form a highly viscous complex mixture of solids, liquids, and gases that contain a variety of solid carbon-based dirt and metallic particles, as well as liquid coolant, fuel, oil and water droplets.
But what can we possibly learn from a sludged engine?
Consider our reliable 40-year-old 10-hp shop compressor that has delivered zillions of cubic feet of pressurized air daily from its ambient temperature shelter. While the electric motor and the V-belts have been replaced twice, the only other routine service this air-cooled V4 compressor has received, other than having the condensed water drained from the tank, is an occasional oil change. When the used, unfiltered HD-30 oil is drained from its crankcase it shows no evidence of contamination or oxidation and looks like fresh oil.
A typical internal combustion engine is just an air compressor in which fuel is mixed with compressed air and then burned. The combustion process generates heat and a variety of reaction products, some of which enter the crankcase as blow-by and contaminate the oil, e.g., fuel, soot, water and other normal reactants, products and byproducts.
Even though the oil temperature is high enough to boil off and extract all the water and other volatile contaminants via the PCV system, this crankcase broth will inevitably change into a deposit that does not drain when the oil is changed. Air-cooled gas or diesel engines are just air compressors in which the engine oil is subject to oxidation because they are exposed to higher temperatures and contamination by combustion products. If the engine is liquid-cooled, the engine oil may also become contaminated with coolant.
Lesson #1: Sludge deposits in internal combustion engines can indicate either stop-and-go driving, lack of proper maintenance, too low or too high an oil temperature or oil contamination.
Sludge formation is not a new problem. In fact, sludge deposits limited the durability of early internal combustion engines. Over the years, oil base stocks were improved, detergent oil additives were developed to keep microscopic sludge-forming solid particles in suspension, anti-oxidation additives were developed to slow the formation of these sludge deposit precursors, and engine oil filters were fitted to remove suspended solid particles from the oil stream and slow the formation of flow restricting sludge deposits on internal surfaces.
Changes in engine oil formulation and treatment accelerated with the introduction of "permanent" glycol-based coolant, another oil contaminant that may accelerate sludge formation. With the recent increased popularity of wet-sleeved engines, as well as the introduction of alternative but incompatible coolants, we are seeing more engine bearing failures.
Lesson #2: Sludge deposits may be due to inferior oil, deterioration of the oil additives or contamination by coolant.
When "detergent oils" first appeared, everyone’s engine repair business increased. Tired, worn out engines, full of sludge deposits because they had always been serviced with non-detergent oils, were ill advisedly transfused with detergent oil, which promptly attacked the sludge deposits. Engine bearing surfaces were flooded with oil containing a high concentration of newly suspended sludge particles. And during the phase-in of detergent engine oils, a number of chemical elixirs for "engine oil desludging" appeared. With current engines, we often encounter similar failures when engines are accidentally overfilled and loosen normally benign engine deposits. Unless you’re very young or your principal residence is a cave, none of this should be news.
Lesson #3: Absence of sludge deposits may indicate the crankcase has been "flushed," especially if fresh oil contains an excessive concentration of solids.
Some years ago we sold some oil, a filter and a pan gasket for a 366 truck engine to a customer who initially was asked to do a routine oil change. He eventually had to remove the oil pan because the engine oil had thickened and would not flow out of the drain hole. Once he removed the pan bolts, the oil pan, very heavy because it was full of thick black goo, fell to the floor. The bozo who had previously contracted to "service" this fleet vehicle had repeatedly neglected to drain the old oil when he changed the filter and topped up the level of the used oil. Exposed to heat for an extended period of time, the old oil eventually oxidized and transformed into a black mass resembling thick molasses or Le Brea tar pits’ crude.
Lesson #4: Always be suspicious of maintenance information.
Today, we see a lot of sludged engines because of two different factors, the trend to ever-higher engine oil temperatures (oil coolers help) and the tendency to neglect or postpone routine maintenance, especially in the case of leased vehicles. When a yuppy BMW owner volunteered that his "Service Engine" light was designed to indicate when he should add some engine oil, I suggested that he might want to change it to read: "Too Late." Engine noises and low oil pressure are obvious indications of inadequate engine bearing lubrication. So, when oil sludge is also found, overextended drain intervals, elevated oil temperatures and/or contamination should be considered as the most likely causes. But there are always exceptions.
Experienced custom engine builders understand that all sludge deposits are not necessarily due to abuse and neglect. When we find a lot of sludge in an engine, we always try to pinpoint the cause(s), do what we can to avoid a repeat occurrence and advise the customer or the installer how to minimize engine sludge formation.
Today, as in earlier times, new and remanufactured engine durability is directly related to the recognition, control and elimination of all factors that support engine sludge formation including, but not limited to, lack of proper maintenance, inappropriate oil temperature, use of an inferior engine oil, and engine oil contamination.
Post Posted: Thu May 09, 2013 5:53 pm
Thats a good read..... Well done on the find.
Users browsing this forum: Google [Bot] and 306 guests
