| Author |
Message |
appsie
 Posted: Fri May 31, 2013 9:27 pm |
lol
kenn
Joined: Tue Nov 11, 2008 10:30 pm Posts: 1202 Location: Melbourne
 Posted: Sat Jun 01, 2013 11:43 am |
Atari you could get a job in their marketing department.
WestVic-Zook
Joined: Sun Feb 03, 2013 11:58 am Posts: 121 Location: Warrnambool, VIC
Vehicle: Zook Monster Truck
 Posted: Mon Jun 03, 2013 7:37 pm |
there was a huge detailed thread on mudrhino in regards to how to make "new style" arb lockers more reliable
Basically the things you need to know and this is what a engineer guy from ARB said was
1. lift your right foot before hitting the air lockers, crash locking under power will chew out the engagement gear, the engagement gear is basically the weak point, spidertrax gears will just destroy more of the diff 2. Run a 150psi pressure switch on your arb compressor, this will help engage the engagement gear quicker before the engine torque hits and this is covered by arb warrenty also 3. if your experiencing oil in your lines this is mainly due to your diff breathers block or possible from water in your diff which causes foaming
rob_macca67
Joined: Fri Sep 28, 2007 11:30 pm Posts: 367 Location: Brisbane - Nthside
Vehicle: 1993 Suzuki Vitara 4dr Wgn
 Posted: Fri Jun 07, 2013 12:27 pm |
rob_macca67 wrote: Bruce wrote: I'm betting chinese.  Yep... spot on  Now it's just a wait and see.... Arrived today
rob_macca67
 Posted: Sat Jul 20, 2013 6:33 pm |
tassie jeeper
Vehicle: 1995 2.0V6 Vitara LWB
 Posted: Sat Jul 20, 2013 9:21 pm |
i have air leakers in the jeep never had an issue with the rear the front is a bit dicky it sprays oil on the underside of my bonnet upon release and has to pump additional air into it every 10 mins or so as it leaks. also sometimes the compressor wont shut off when i turn the front locker on and i have to disengage/re-engage to get the compressor to shut off (however i have had no structural issues and thats running 35" bias ply tyres)
pickles09
Vehicle: 1981 suzuki 1.3l corolla
 Posted: Mon Jul 22, 2013 5:12 pm |
Bit of a noob question but can you run a air line off them as we'll to pump up tyres ect?
klutched
Joined: Wed May 16, 2012 3:46 pm Posts: 1691 Location: Brisbane
Vehicle: 99 Grand Vitara
 Posted: Mon Jul 22, 2013 6:42 pm |
pickles09 wrote: Bit of a noob question but can you run a air line off them as we'll to pump up tyres ect? You could but I'd imagine it would be really slow.
atari4x4
 Posted: Mon Jul 22, 2013 6:53 pm |
the air compressor pictured above is NOT designed for tyre inflation
Sco-tie
Joined: Fri Apr 06, 2012 5:02 pm Posts: 928 Location: Adelaide hills!
Vehicle: 04 Grand Vitara, 2.5L, V6
 Posted: Mon Jul 22, 2013 6:56 pm |
ARBs air pump t-s off to the air lockers and has a plug in for pumping tyres
tassie jeeper
 Posted: Mon Jul 22, 2013 10:24 pm |
Sco-tie wrote: ARBs air pump t-s off to the air lockers and has a plug in for pumping tyres yes but it will kill the compressor in no time flat i have a mate that works at arb and does just that and has killed like 3-4 compressors but get a new 1 for next to nothing so does not care
fordem
 Posted: Mon Jul 22, 2013 10:54 pm |
Sco-tie - where is that ^^^ compressor mounted?
atari4x4
 Posted: Mon Jul 22, 2013 11:03 pm |
looks like the underseat compartments under the back seat in a dual cab hulix
Sco-tie
 Posted: Tue Jul 23, 2013 1:25 am |
tassie jeeper wrote: Sco-tie wrote: ARBs air pump t-s off to the air lockers and has a plug in for pumping tyres yes but it will kill the compressor in no time flat i have a mate that works at arb and does just that and has killed like 3-4 compressors but get a new 1 for next to nothing so does not care That is how they are installed, The pumps have a good warranty and i haven't heard much about the systems failing especially in regard to the solenoid system for the lockers. fordem wrote: Sco-tie - where is that ^^^ compressor mounted? yes atari4x4 wrote: looks like the underseat compartments under the back seat in a dual cab hulix
atari4x4
 Posted: Tue Jul 23, 2013 1:31 am |
where is my gold star?
Sco-tie
 Posted: Tue Jul 23, 2013 1:51 am |
atari4x4 wrote: where is my gold star?
jonfromhamilton
Joined: Mon Dec 26, 2011 2:11 pm Posts: 410 Location: Pakenham
Vehicle: SJ51T
 Posted: Sun Sep 29, 2013 9:35 pm |
my rear locker just started leaking >_< having some diff issues when turning but it seems to involve the locker somehow. the faster i drive, the more the compressor has to "top up" the resevoir to keep the locker engaged so figure its the "quad ring" (technical term) for the new locker style. which is viton by the way (higher wear resistance and temperature resistance) I will be pulling this out over the next few nights and if I remember i will post up some pics or make some coments.
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
Vehicle: 03 Jimny
 Posted: Mon Sep 30, 2013 12:19 pm |
Could be your crown wheel slightly touching the copper line or could be your seal housing ring.
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
christover1
Joined: Tue Jul 15, 2008 11:30 pm Posts: 8203 Location: Melbourne
 Posted: Sun Nov 30, 2014 6:53 pm |
My Chinasoong locker came with O rings seals fitted. But also came with a set of what I assume is X ring seals. The O-rings leaked a lot, so fitted the X rings and leaking was very much reduced.
