It is currently Sat Oct 31, 2026 2:42 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
Post Posted: Thu Jun 06, 2013 11:55 am
yay, wonder if any internal damage was done with all that grinding... i'd change the oil & have a suss for metallic bits.
Vehicle: 99 Grand Vitara
Post Posted: Thu Jun 06, 2013 11:59 am
yay, wonder if any internal damage was done with all that grinding... i'd chane the oil & have a suss for metallic bits.
Of the diff or the transfer? I opened the diff and had a look at it. Looked all good, no metal or anything :D I think I should change the transfer oil too. Can I use the same shit I used in my diff? It says 75W/90 but I have 80W/90
http://www.strictly4x4.com.au
Post Posted: Thu Jun 06, 2013 12:05 pm
the transfer case :roll:
Post Posted: Thu Jun 06, 2013 12:14 pm
Post Posted: Thu Jun 06, 2013 12:19 pm
if the manufacture specifies a different weight oil, it's usually for a reason.
Post Posted: Fri Jun 07, 2013 1:19 pm
Dropped the oil in the transfer case..... was disgusting, came out looking like chocolate milk... put some oil through to flush out the crap then put some fresh stuff in..
Post Posted: Fri Jun 07, 2013 1:21 pm
water in the oil.
that can cause nasty bearing damage if its been in there long
Post Posted: Mon Jun 10, 2013 1:23 pm
Hmm, think my transfer is stuffed... Went up Cruiser park for the weekend and it just doesn't want to put drive to the front wheels under load and still makes the grinding noise even though I have a vitara CV in there now :/
Post Posted: Mon Jun 10, 2013 1:27 pm
going by the noises it was making & the fact that you kept at it, i reckon you've done some major damage somewhere, does the front drive shaft from the xfer case to the diff still spin when it's making the noise & not putting drive down?
SV 2.0l vitara 26 spline CV or just a normal SE 1.6l 26 spline CV ??
Post Posted: Mon Jun 10, 2013 1:37 pm
Not sure if it spins hard to get a good look under there while it's under load.
Not 100% sure but I think it's a 1.6, got it off swifty
Post Posted: Tue Jun 11, 2013 4:10 pm
Sooooo, put the GV up on the stands this arvo and put it in 4H and 4L and no drive to the front wheels in either but I can turn the pinion with my hand and it turns smoothly. So new transfer me thinks...
Also when I turned the pinion one CV goes forward and the other goes backwards? Is that correct? Thought they would both go forward :/
Post Posted: Tue Jun 11, 2013 4:53 pm
correct on the circle spin ratio, one wheel will reverse rotate due to it... :rofl:
Users browsing this forum: No registered users and 252 guests
