It is currently Sun Aug 02, 2026 2:08 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2
Post Posted: Thu Jun 26, 2014 5:06 pm
geez you lot get complex for no reason, just put a big alternator and optima in with a digital volt gauge and go from there, for all you know your current battery is just stuffed.
Even the winch racers with dedicated 24v winch systems run out of power if they dont pay attention
Vehicle: Suzuki Jimny 2009
Post Posted: Thu Jun 26, 2014 6:55 pm
jonno_racing wrote:
Is thr d51 the same size as a stock zook battery?
Bigger but it fits in the same spot for a Jimny anyway. It is the biggest that will fit.
Post Posted: Thu Jun 26, 2014 6:56 pm
That is actually all I do myself Royce. If I don't pay attention and stuff the battery my secondary is the same sort.
Vehicle: sj51
Post Posted: Thu Jun 26, 2014 9:17 pm
My winch runs off my second battery, that way when the carbie claps out on angles I can winch the nose down to get it restarted, without fear of a flat main batt.
my main battery can also help supply some grunt when the engine is running, either if the redarc is auto engaged or if I manualy switch it
it hasnt let me down yet, and as you know josh, my poor driving normally results in winching
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Jun 26, 2014 9:32 pm
This was going to be my suggestion... There's heaps of room on the drivers side for whatever sized battery you want really. Coupled with a falcon altenator (which you already have ;) ) would be a shit ton better than current setup, and would mean us not having to lever the goat with big sticks in the middle of whoop whoop cause we couldn't start your car hahahahaha
Post Posted: Thu Jun 26, 2014 10:01 pm
Nice idea pezz! Will keep thinking on it.
Haha I will not forget that anytime soon. Took quiet a bit of effort and luck to do that. Battery voltage display ordered. Hopefully order my optima in the next 2 weeks.
Post Posted: Thu Jun 26, 2014 11:04 pm
What gauge??
Did you get a yellow top from eBay?
Post Posted: Fri Jun 27, 2014 5:56 am
This display- couldn't find anything more expensive or would work for my application.
http://m.ebay.com.au/itm/271494974878?t ... 5760300017
This is the battery ill be ordering.
http://m.ebay.com.au/itm/291046921162?n ... ING_ACTIVE
Post Posted: Fri Jun 27, 2014 5:57 pm
31Zook
Dont buy the D51R. You need the D51. On the 51R the terminals are on the wrong side of the battery.
Mike
Post Posted: Fri Jun 27, 2014 6:04 pm
Whoops, this one then.
http://m.ebay.com.au/itm/321229281329?nav=SEARCH
Post Posted: Sat Aug 02, 2014 7:15 pm
Ordered the optima battery, it cranks heaps better and fits really well.
Post Posted: Sat Aug 02, 2014 10:21 pm
Sorry I missed your post back at the end of June but I see you got the correct one. I just insulated the terminal but it does not touch the bonnet.
How are the bonnet struts going. Are they the same ones Zukenutter has? From Korea I think?
Post Posted: Sun Aug 03, 2014 11:49 am
Yeah great, ive had no dramas with them, 2 bolts per side and they clip in.
Same as zukenutter. I just copied him.
Vehicle: suzuki.sierra.88
Post Posted: Sun Aug 03, 2014 7:48 pm
I just bought the biggest battery that I could physically fit in. Works great now. Can winch without problems or stoppages unlike before on a stock battery. Alternator upgrade will help the battery cope better.
Post Posted: Tue Aug 05, 2014 5:18 pm
Probably regurgitating what has already been said but...
I have a M8000. Put the biggest yellow top in. No change to alternator. With reasonable use on a mad day of fun, I have no dramas. I have even winched for a couple of minutes engine off and started no trouble.
Vehicle: SJ80, SE416
Post Posted: Tue Aug 05, 2014 7:28 pm
Just throwing this out there in this old thread for all the tightarses just like me...
I bought one of these:
http://www.supercharge.com.au/supercharge-gold-plus-mf55b24r
Same size as an optima D51, but higher CCA, more reserve capacity and only $128 with a 40 month warranty.
Users browsing this forum: No registered users and 433 guests
